Results 1 to 13 of 17
    Aug 2009
    American Standard AC with York furnace?
    My tech is recommending the switch as he prefers AS over York for cooling.
    Another company we like prefers Carrier.....
    Thoughts and suggestions welcome.
    No real problem.
    As long as the indoor coil is matched to the A/C and there is proper airflow, no problem. Only issue would be efficiency ratings that require a specific ECM blower inside, usually above 14 SEER.
    Aug 2009
    Thanks....another question.
    Since we have a two-stage furnace, does the AC need to be two-stage, as well?
    If so, and we go with two-stage, does it help humidity issues more than single stage?
    If you have a variable speed furnace, you CAN use a 2 stage A/C. With standard blower, even if 2 stage gas, really not the optimum way to utilize the advantages of a 2 stage A/C.
    Aug 2009
    Thanks, BL.
    We do have a two stage blower in the furnace.
    Would we benefit, particularly lowering humidity wise, going with two stage AC?
    Is it a variable speed blower? Know the model # of the furnace?
    I don't know
    Can't it be done with an additional relay?
    Quote Originally Posted by amd View Post
    Usually not. Can't control the blower speed enough.
    Fanhandler and ICM both make a control that can be added. But, you still don't get the same operation as a VS blower.
    You either loose some A/C efficiency, or humidity control with both of them.
    Dec 2006
    Middle Tennessee
    any "2 stage" blower these days IS most likely a variable speed motor
    now, if we only knew the model and serial number
    Aug 2009
    The furnace is a York Affinity PVC9CONUP11 92.02 two-stage (left old condenser coil)
    White Rogers IF85-275 programmable thermostat.
    The old AC is a 15 year old Concept (still looking for info)-don't think I have the manual anymore.....believe it is 4 ton...2900 sq ft house
    That furnace will work fine with a 2 stage A/C. Its a VS blower.
    Aug 2009
    Thanks!
    But............does a two stage eliminate MORE humidity?
