Results 1 to 13 of 14
Thread: Pump Module
    Here's a pump module we fabricated recently.
    [Edited by blackearth on 10-06-2003 at 08:11 PM]
    Thumbs up
    Nice work blackearth!!! tekmar 363 or 364, isoflanges on all pumps, clean joints. you dont mess around do ya?
    Nov 2000
    Waco, Texas, USA
    I bet he built structures out of tinker toys as a kid
    "And remember my sentimental friend......that a heart is not judged by how much you love, but by how much you are loved by others" - Wizard of Oz.
    Oct 2001
    Very nice looking job indeed. I would like to learn something from it,
    so here are my questions.
    Is this residential application?
    There is a group of valves to the left of Tekmar controller.
    Two gate or stop valves with green handles and ball valve between them. Why three valves in a row?
    What is the brass part above these valves?
    [Edited by sigma on 10-07-2003 at 09:17 PM]
    Yes this is for a residential application. The valves to the left of the Tekmar 363 are a ball valve with boiler drains on each side for filling. The brass part above the valves is the automatic air vent, a Honeywell Sparco Powervent. Those Powervents work very well.
    more questions
    is this a low temp application?
    how are you heating the house? air handler/baseboard/cast radiators?
    there is a lot of water movement if all zones are calling?
    is a 1" feed to supply adequate??
    just some thoughts
    great work!!
    SWEET
    Oct 2001
    [QUOTE]Originally posted by blackearth
    [B] The valves to the left of the Tekmar 363 are a ball valve with boiler drains on each side for filling.
    I could not tell from the picture that
    they were drain valves.
    Thanks.
    Talking
    Nice looking, but where is the blower motor?
    Wink
    Yes this is for a low temp application. The upper pump feeds a floor with above-floor heat transfer plates. The next one down feeds a manifold for the lower level slab. The house is around 2000 sqft so 1" feeds are more than adequate.
    As for the blower motor, you could mount one behind the whole thing and heat the mechanical room ;-)
    Jan 2003
    SE Pa
    Talking NO, NO, NO
    It's just one of them fancy european towel warmers!
    5 out of 4 people don't understand fractions
    Jul 2001
    Buffalo N.Y.
    Talking
    You forgot to install a boiler, don't you hate when that happens.
    Jun 2002
    St Louis MO
    I dont see a burnt fitting one , very nice looking with everything square , straight , plumb and level .
