Results 1 to 13 of 19
Thread: RTAA-300 LEAK
    Jul 2009
    RTAA-300 LEAK
    Hey guys just wanted to throw this one out there. I put lip seal by passes on a & b compressors,on circuit 1. I started to fill with nitrogen for a 3 time evacuation but kept losing pressure , looked and looked with soap bubbles, honestly I was getting ready to punt, finally found the leak, my question to you all (where was it?) Hint: It was not in any fittings . Tim
    Aug 2000
    Under my tree
    Tube sheet? Compressor casting?
    To much work with too little time!!!!
    Nov 2007
    I am unsure myself
    My guess on your guages
    Aug 2009
    Seattle Area
    The most frustrated I've been yet with a leak repair was an EXV on an RTAA leaking at the electrical connections.............at the terminal board midway on the machine!!
    Jul 2009
    answer
    At the electrical terminal on the motor, 6 studs coming out of motor, all where loose,tightened ,problem leak gone. I think I also age a few years in the process. Tim
    Indiana
    That is the most common and first place to look on a RTAA. You don't want to just tighten them you want to rework them with the new insulator and o-ring design. If you megged the motor it would probably meg low due to rust under those original insulators.
    ottawa canada
    If the insulators are square then you should replace with the new style rounded ones . They shed the condensation better and prevent the corrosion between the insulator and the terminal plate and the leaks that go with that corrosion.
    Jul 2009
    Humbled
    Thanks , I very much wecolme the input. These units are only 11 years old ,do all the chillers you guys work on have as many problems and need as much updating as these rtaa-300 and what is your honest opinion of them ? And Who makes the best chiller ? Thanks Tim
    Jul 2009
    Long year
    Well it looks like I will be back at it.
    Apr 2004
    Lombard, IL
    Trane still makes the best chiller Tim. We have outstanding products. Any rotary compressor is going to have the same issues whether it is made by trane or not. Its mechanical and things break. Yes it is hard to stop a trane. Not impossible.
    Not in Iran
    i enjoy working on the rtaa., and espscially on the cvhe and f.,
    also ., i just bought a digital megger., is anyone famuliar with these., of course is made in china.,
    any input
    MEXICO
    TUBING ECONOMIZER
    Quote Originally Posted by servicetrane View Post
    TUBING ECONOMIZER
    what?
