Results 14 to 21 of 21
Thread: compressors
    Aug 2009
    Pittsville, MO
    Not all of it, only a very small amount.
    that was my thought I was just making sure. I just have never heard of checking oil in a hermetic. I just thought they ran until they were bad then you change it. Or replace the unit most likely.
    I have never done it.
    Some larger tin cans have sightglasses to monitor oil level.
    Don't get your heart set on too many replaced units. If the customer just replaced everything that broke, you'd be out a job.
    Southeastern Pa
    I disagree. If I do the replacing, I'm working! And there are so many customers, work would back up if everyone approved my quotes!
    I also only see sight glasses for oil on the larger hermetics.
    Is there a reason you (original poster) are asking this question?
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Quote Originally Posted by timebuilder View Post
    Never thought of it that way.
    Most of what I see with tin cans are small display and storage cases. Lots of fix work, but when it's time for replacement, no work for me.
    Southeastern Pa
    For me, it's 5 to 15 ton splits, and RTU's up to about 25 tons.
    Compressors? Lot's of em. Two last week alone.
    I know what you mean about the display cases. Unless the store has a change-out arrangement where they just cart in a different case, we usually replace the entire condensing unit. Once, I replaced a capillary tube. Other stores just send them to a warehouse and send out one that works.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Dec 2008
    Southeast MIssouri
    I have drilled and tapped an oil port in the side of a tin can, near the bottom, to drain and change oil.
    Apr 2004
    Muskegon, Mi.
    Quote Originally Posted by Royster88 View Post
    How do you check the oil level in a welded hermetic compressor?
    Use your dipstick, Jimmy.
    Aug 2009
    Pittsville, MO
    and snap into a slim jim
