Results 1 to 2 of 2
    Sep 2009
    Jefferson SC
    Heat Pump Questions
    I have a question im new to the HVAC thing but i do know a little bit just need some advice from more experienced people hope there is someone out there that can help... If you have a heat pump and its working in the cooling mode and you have frost on the evaporator and the suction line all the way to the compressor i know two things to look for are proper air flow to the evaporator and that it also could be that there is not a proper refrigerant charge on the system is there any thing else that i should be looking for the system is an american standard 3 and a 1/2 ton and the ambient air is around 80 to 90 degrees
    Sounds like its time to call a service company.
    Sorry, this is not a DIY site. So we can't help you.
    Thread closed.
