Thread: Coil and plenum vs Alstyle
09-04-2009, 12:54 AM #1
- Jun 2009
- 22
Will I get better or more air flow with a coil and plenum than with an Alstyle coil?
09-04-2009, 11:09 AM #2
no difference
With using either one you need a good fitting coil,with no air bypass.
So if the coil fits like it should, you shouldn't see any difference.
A cased coil is the same as a plenimum and coil. I think you mean ALLSTYLE.
Go to their website and look at the difference between cased and uncased.
Airflow is everything..well mostly. I've not used that brand, so other will advise [usually] as to their long life or not..
09-04-2009, 11:17 AM #3
Avoid All Style plenum coils at all cost; end of story.
09-04-2009, 11:30 AM #4
- Oct 2004
- Hurst, Tx.
- 86
Good post Classical. Allstyle coils are the worst things ever invented and airflow will be better with a coil and plenum.
