Results 1 to 10 of 10
    Rooftop central unit vs makeup
    What is the main difference between a rooftop central unit and a makeup unit?
    Indiana
    make up unit takes in fresh air to replace air that is being exhausted out of the building by another means...i.e. exhaust fans, kitchen hoods, industrial ovens
    Generally speaking, wouldn't the central unit be capable of compensating for exhaust fans, kitchen hoods, industrial ovens?
    The makeup is more than just a fan, it can heat or cool the air right?
    Indiana
    Quote Originally Posted by guitarboyled View Post
    most in my part of the country are heat only. No a rooftop unit would not be able to supply the amount of air needed in kitchen hoods and industrial ovens.
    an old account we had before the plant shut down had 8 Makeup units with a BTU of 5 million each. air openings where aprox 5' X 12' Would u need one if u just had small fans for bathroom and let say an air brush station...probably not. but only IF the ac units fresh air damper is set up properly
    Jul 2001
    Southern NJ
    I think it sometimes just depends on what the architect calls them on the blueprints.
    I also get confused about unit ventilators, cabinet unit heaters, fan coils, air handlers, and a few other names on prints for seemingly identical equipment.
    Ryan
    Maintenance Guy
    naysayer, skeptic, conspiracy theorist
    Therefore, if nothing is sucking important volumes of air out of a room, it won't require a makeup.
    Technically an exact same unit could be used as a central unit in one application and as a makeup in an other?
    CHICAGO SUBURBS
    RTU's return air from space and recirc. it, only adding a minimal amount of makeup (outside) air. When you have need for a lot of air exchange I.E. auto painting or some industial process or a commercial kitchen, you are removeing a great deal of air that needs to be replaced to support human life, combustion of other equipment, and space positive pressure. I work in buildings that have both RTU's and make up units in the same zones. Winter temps in Chicago are cold and as the gentleman from Indiana said, if you are removing alot of exhaust from a building space and replacing as much or more in the winter around here, you better have some big burners on your make up air unit. Usually direct fire burners.
    Jul 2009
    eastlake,ohio
    Most package rooftops at design temp can't handle more than 30% outside air,and to keep fresh air design for people load and exhaust loss,whatever reason a make-up unit would be used.We do alot of kitchen exhaust canopy's and some jobs we dump fresh tempered air into kitchen area,about 80% of exhausted air ,and on some jobs we close loop and dump in front and in and at the floor of the kitchen hood.This stops the loss of your conditioned air from the dining room,and backdraft of flue fumes.(and flies don't come in the front door at 120 mph)
    What if a relatively small new addition is added to an existent building. Would the unit providing air be called a secondary central unit or a make-up?
    Indiana
    i think our definitions are mixed up...give us your definition of each and then we will go from there. like mentioned before ive seen units named different things by architects.
