Results 1 to 13 of 17
    Aug 2009
    southeastern wisconsin
    The effects of no intake pipe on 90% furnace
    What are the effects of not installing the combustion intake pipe or baffle on a 90% efficient furnace? My guess, is it would burn hotter and cause the heat exchanger to wear out 10 years earlier then it should. Just looking for advice from someone with a little more experience.
    I dont like them and do not use them if i dont have to. Most are 1 or 2 pipe.
    I think its bad to bring cold outside air in and dump it on a burner myself.
    Wait till the combustion guys get here we may both learn something.
    Won't cause it to harm the HX if its been set up right.
    Aug 2009
    This Furnace was a Payne Don't have model and serial #'s but it had holes for the intake I just thought someone was to cheap or to lazy to run the extra pvc pipe.
    Aug 2009
    Beatrice, NE
    It is going to depend on the manufacturer, some will require it others don't. I believe that some brands it even varies model to model.
    Dumping cold air onto a burner isn't going to make any difference, the burner just wants the O2 it doesn't care about the temp.
    It also depend on where the unit is located. If it is in the conditioned space why use air that you have aready paid to heat just to run across burners and blow outside, only to be replaced by cold air coming in around doors and windows. If it is in anywhere outside of the conditioned space the air intake won't make much difference, unless it is in a contaminated area.
    S.E. Pa
    Cool
    In a small CAZ, it can depressurize the room and backdraft a gas WH. It sucks air out of the house causing some passive infiltration.
    Aug 2009
    Nothing is wrong with the heat exchanger I just thought it needed intake pipe and baffle. It was a new install and I have never seen just a exhaust pipe and no intake pipe. I'm still new in the field.
    Aug 2009
    This furnace didn't have a baffle or intake pipe to control the oxygen. My question is if it has too much oxygen will that cause it to run not as efficient?
    Aug 2009
    Beatrice, NE
    Excess air in a burner will lower the efficency. The Nitrogen in the air will soak up some of the heat in the HX. If you run a Combustion Analysis you can tweak the air/fuel ratio and gain efficency by controling excess air.
    Mid Michigan
    It will be less efficent by a few percent because it is useing indoor air for combustion instead of outdoor air.
    I have found wood stacked under the intake for 90% furnace.
    It snowed and they had no heat.
    I found the furnaces sealed burner cabinet full of snow.
    I had to clean out the snow and replace the units 3 wire pilot (Carrier) worked like a champ after.
    Waddya mean don't thaw out the frig with a knive?
    Northeast Ohio
    We only vent with two pipes, period. Several reasons the main being we want the combustion air coming from the outside so that it is in the same pressure zone as the exhaust and not taking air from the interior causing negative pressure and air infiltration.
    DEM
    Quote Originally Posted by kls-ccc View Post
    By adjusting the secondary air ports correct?
    I will have to investigate to see if efficiency is lost on my units, i know it depends on brand etc.
    Around here there are very few houses tight enough to worry about air infiltration. I only wish it were a problem in my house,leaks like a sieve
    Cincinnati, Oh
    ...if the furnace is in a big open basement, your fine. If it's in a closet, or anything considered to be a "confined space", then you need the 2 pipe.
    Hearthman: If the space is small enough to backdraft a water heater, then the water heater should have a C/A anyways .
    "Just get it done son."
    Dad adjusted
