Results 14 to 20 of 20
Thread: Tower water temps
08-27-2009, 11:12 PM #14
- Mar 2003
- Brooklyn, Ohio
- 102
It sounds like you might have a bypass somewhere in the piping. Can you check the suction and discharge of the pump and look up the curve? I would also want to know what pressure drop is reguired across the barrel.
08-27-2009, 11:53 PM #15
I'd start with cleaning the strainers at the pump and in the tower.
You should be able to get within 6-8 degrees of wet bulb.
Maybe there's a tower by pass for minimum temp, and it's not modulating.God Bless the USA
08-28-2009, 12:25 AM #16
- Oct 2007
- california
- 57
Might also want to check if tower has modulating dampner on fan..is it open?
08-28-2009, 01:28 PM #17
- Jan 2008
- pennsylvania
- 117
08-28-2009, 03:44 PM #18
don't forget to also check the spray heads and trees for blockage. and if you're growing algae, you may have other bacteria thriving - i.e. legionella - be careful!!!!!!!!!!
08-28-2009, 06:34 PM #19
- Sep 2005
- Texas
- 2,793
08-28-2009, 06:55 PM #20
what is the brand of tower and model...your looping tower return water with towering entering to the chiller someplace.the tower will only do its 10F as you have typically.
"when in doubt...jump it out" http://www.youtube.com/watch?v=aMy-sAHwS4E
