Results 1 to 10 of 10
    tidewater, va
    York purge drum replacement repipe
    York types:
    Got a replacement drum from York, P/N 375-21362-000 and I am trying to get an instruction sheet to see what York wants upgraded. Looks like the same tank with a few different fittings. Anyone have a cut sheet on this tank? thanks.
    r404a
    Western Wa
    Just curious, what led you to replace the entire drum/tank?
    I've got one with a bad top level switch. I plan to replace the switch assembly, which I have done before on the older version.
    God Bless our Veterans
    God Bless the USA
    tidewater, va
    something is screwed up on the treaded section on the tank where the float screws in, had a bear of a time stopping a leak there and new style is the oring type
    r404a
    Aug 2000
    Under my tree
    Should have just scrapped it and went with a Purifier or a Redi purge. JMHO
    To much work with too little time!!!!
    windy city
    Quote Originally Posted by absrbrtek View Post
    ditto - then you can run purge with machine off. done a bunch of them.
    Dec 2008
    Dixiana, AL
    I'll third abs and dad, but now that you've got what you've got, you'll need to change the inlet fittings to SAE straight-thread o-ring fittings as necessary, or order the old tank if available (don't know if it was discontinued) and send the new style tank back (and suck up the restocking fee). Or, you could just call Redi and get you a Skyguard.
    Western Wa
    Oh, *&%$#@, I hope I ordered the right one.
    Anybody know when they changed over?
    The one I'm working on is from 1999, I think.
    It looks different than the old pipe thread one, so maybe I lucked out.
    It's the pump assisted type.
    God Bless the USA
    Dec 2008
    Dixiana, AL
    Quote Originally Posted by Randy S. View Post
    Pipe thread switch has a square head, O-ring sealed switch has a hex head.
    Western Wa
    Thanks.
    This one has the hex head, and that's the number I ordered. Looks to be a 1 1/2" hex. Should be much easier than the older style that I did last time on another unit.
    To get the old style out, I used a 1" drive socket upside down on the square head, with a big bolt in the socket, and a pipe wrench on the bolt.
    God Bless the USA
    Dec 2008
    Dixiana, AL
    Thanks.
    Should've told you that's a 1.5" fit on the new one. I use a deep-well 1" 8 pt Proto impact socket on the old style, 3/4"drive.
