Results 1 to 7 of 7
    Aug 2000
    Central Oregon
    This is in a 3 story foam with cement infill home.
    The line-set from #@*& is done.
    Another view, The H.O. changed his mind so we ended up running the line set this way through this unreal crawl on the otherside of that 10" thick wall.
    Last one. Picture taken prior to final cleaning.
    It takes a little longer, and looks better, a lot longer.
    This post only took me 3 times to get it right,lol comfooters ??
    [Edited by Tempted on 09-10-2003 at 12:15 AM]
    If you think our goverment is screwed up. You haven't lived in another country.
    manitowoc wisconsin
    It's always fun to change something after it's done lol
    [Edited by markwolf on 09-10-2003 at 12:15 AM]
    Take your time & do it right!
    Aug 2000
    Central Oregon
    Ok who edited first? lol
    Apr 2003
    Hmm
    Questions........
    1.) Where are all the Hydronic Controls?
    2.) How much distance is between the hieght of the coil and condensor?
    (that line set can't be doing the compresser any justice)
    3.) How's all that copper supported?
    p.s. Don't ya just love that Polyken labeled tape? lol
    Aug 2000
    Central Oregon
    The controls for the infloor in the garage are to the right, next to the other water heater.
    The air handler has a pump inside it with a coil that the water runs through. Controlled by a stat upstairs.
    The line set goes through the wall then to the left about 17', then up 3' and out to the condensing unit. So about 40' of line set. 13 or so vertical and the rest horizontal.
    This is the home of a contractor/builder. It's his choice of everything. The condensing unit was going to the right out the other wall about 20' away.
    I do beleave this is our last job him.
    Aggrivation cost $$$$$$$
    in a house, Appomattox, Va.
    I put one of those in a few mo ago. must have been the guys twin! He also asked if we could do some sort of weird stuff with it if the garage got CO in it so wouldn't get pulled in house. why don't you just tie the CO detector to OPEN THE GARAGEDOOR if ther's CO from car?- like you'd run one with the door closed. Must be too simple answer for an engineer
    Nice lineset. too
    Col 3:23
    Markwolf You're to kind.
