Results 1 to 13 of 36
08-19-2009, 12:12 AM #1
Why is there an arrow on a drier?
Call the other day...here are two of the more blatant issues. You mean the door should seal? or Which way does it go together? Maybe I should have asked why put the sightglass before the drier? Also the "crack' in the door was almost 4".
08-19-2009, 12:31 AM #2
Duh, everybody knows the arrow points to the compressor.
Zach
08-19-2009, 02:55 PM #3
Just turn the sticker around.
If a nation expects to be ignorant and free, in a state of civilization, it expects what will never be. (Thomas Jefferson 1816)
08-19-2009, 03:35 PM #4
08-19-2009, 03:52 PM #5
08-19-2009, 04:17 PM #6
I got one of those High Performance driers once- The HP type. Opened the box the arrow pointed both ways. Threw it away. Who has time to figure it out.
08-19-2009, 08:19 PM #7
- Jul 2008
- st. louis. il
- 31
08-19-2009, 08:40 PM #8
The arrows are there to indicate left hand and right hand driers. You should always have both left and right hand driers on your truck because you never know if you are going to run into a unit on the left or right side of the house.
Government is a disease......masquerading as its own cureEcclesiastes 10:2 NIV
08-19-2009, 08:52 PM #9
08-19-2009, 09:06 PM #10
arrow points towards your truck where you get in and drive away saying "good luck with that"!
08-19-2009, 10:36 PM #11
drier
That's why I use Bi flow driers. That way I am always right.:>
08-19-2009, 10:40 PM #12
08-19-2009, 10:43 PM #13
That arrow tells you which direction to throw it.
