    30 year old GE central unit 5- ton
    how much freon would a 5-ton general electric central air unit hold the unit is around 30 years old. started with a suction pressure of 60 and head pressure of 250. to get it to 70 on suction pressure had to put 10 lbs of freon in. the air handler, heat exchanger and evaporator are as big as a rerfigerator.
    makes sense that a bigger evaporator would hold more freon but that much?
    thanks gwalk
    Apr 2008
    TEXAS
    sorry dude no diy, read the rules!
    "When the people find they can vote themselves money,that will herald the end of the republic" - Benjamin Franklin
    "Government is not reason, it is not eloquence, it is force;like fire, a troublesome servant and a fearful master. Never for a moment should it be left to irresponsible action"- George Washington
    I don't know
    I wouldn't worry about how much refrigerant it's supposed to hold, because the charge probably changes the second you finish topping it off. (leaks)
    Nov 2008
    Meriden, Kansas
    O.M.G. Stop adding refrigerant before you hurt somebody! Get someone to check it out who understands superheat, subcooling, etc.
    Anything I say here is only my opinion. Even if you understood what I said.... What I said may not even be what I meant.
    Lancaster PA
    Call a service company.
    Sorry, this is not a DIY site. We are not allowed to help.
    If you are in the trade, get your post count up to 15, and apply for pro membership.
    Once accepted, you'll have access to the pro tech forums, and educational forums.
    Thread closed
    Last edited by HeyBob; 08-17-2009 at 07:45 PM. Reason: added the o to count.........oops! ROTFLMAO
