08-17-2009, 07:00 PM #1
New Guest
- Jul 2009
- 1
30 year old GE central unit 5- ton
how much freon would a 5-ton general electric central air unit hold the unit is around 30 years old. started with a suction pressure of 60 and head pressure of 250. to get it to 70 on suction pressure had to put 10 lbs of freon in. the air handler, heat exchanger and evaporator are as big as a rerfigerator.
makes sense that a bigger evaporator would hold more freon but that much?
thanks gwalk
08-17-2009, 07:06 PM #2
sorry dude no diy, read the rules!
"When the people find they can vote themselves money,that will herald the end of the republic" - Benjamin Franklin
"Government is not reason, it is not eloquence, it is force;like fire, a troublesome servant and a fearful master. Never for a moment should it be left to irresponsible action"- George Washington
08-17-2009, 07:15 PM #3
- Sep 2002
- I don't know
- 2,888
I wouldn't worry about how much refrigerant it's supposed to hold, because the charge probably changes the second you finish topping it off. (leaks)
08-17-2009, 07:26 PM #4
- Nov 2008
- Meriden, Kansas
- 435
O.M.G. Stop adding refrigerant before you hurt somebody! Get someone to check it out who understands superheat, subcooling, etc.
Anything I say here is only my opinion. Even if you understood what I said.... What I said may not even be what I meant.
08-17-2009, 07:31 PM #5
Call a service company.
Sorry, this is not a DIY site. We are not allowed to help.
If you are in the trade, get your post count up to 15, and apply for pro membership.
Once accepted, you'll have access to the pro tech forums, and educational forums.
Thread closedLast edited by HeyBob; 08-17-2009 at 07:45 PM. Reason: added the o to count.........oops! ROTFLMAO
