Results 14 to 24 of 24
    Western Wa
    I like to add a drier to the liquid return from the purge, if possible.
    God Bless our Veterans
    God Bless the USA
    Jun 2009
    Florida
    Quote Originally Posted by heavymetaldad View Post
    it's off on another job at the far end of town. it was a 480 water heater, with a small 120 pump and control circuit, all mounted on a 2 wheeler. needs a 480v, 30a 3phase and 120v,15a single circuits. when it comes back, i'll make a list and snap a coupla pics.
    i do have a cold trap at my job site. that i can make a material list and provide pics
    I used a Prevac portable at Trane. Nice unit, except you could only use it on 480 unless you changed out the transformer and PC board and we had a few machines that were 208, with no 480 close by. I'd like to set one up for dual voltage for those times I come across another 208 machine. Maybe use a multitap transformer with an access panel to change the voltage and learn to live with the lower heat output when necessary. I'd like to know who supplies the hotbox for Prevac.
    Low Pressure Forever!
    If you know heavy metal, you can work anywhere-Dave Andreson
    Anchors Aweigh my boys, Anchors Aweigh!
    Farewell to foreign shores, We sail at break of day. Through our last night on shore, Drink to the foam. Until we meet once more. Here's wishing you a happy voyage home!
    Aug 2009
    Seattle Area
    Quote Originally Posted by ChillerWisperer View Post
    I've used the pressurizer from reftec and it is great because the heater can be wired up to 230 or 480. It's a little spendy buy is well worth it if you were not going to build one and just spend the money. The pump is 115 so as long as there's 230 or 480 avail for the heater you're set.
    http://www.reftec.com/shop/category.aspx?catid=4
    Jun 2009
    Florida
    Quote Originally Posted by NWMech View Post
    That is a nice little unit. And Reftec is right down the road from here...I've been to their new place at Lakewood Ranch and it's a clean setup. I'll check into it. Thanks.
    Jun 2009
    Florida
    I'm pushing for a portable boiler to leak check machines and getting some flak about it.
    First job I get sent on to leak check a chiller, I ask my boss: "so where's the boiler" He says the customer has one onsite that I can use. When I get there, this is what I found:
    ottawa canada
    So when the "home made" boilers explode and you or someone else gets hurt or worse and the appropriate authorities investigate and find that the "home made" boiler has no ESA or CSA approval stickers on it . WHO'S A$% is on the line ????????????????????????????????????????????????
    JMHO........
    Dec 2008
    Dixiana, AL
    Sometimes there's a great chasm between knowing and understanding.
    Mesquite Tx.
    www.hotwaterheater.com
    Jun 2009
    Florida
    Double bogey, thanks for the link.
    Don't worry, I didn't actually use it. The customer had it hooked up when I got there, but I disconnected it and found a hot water source close by that I could use (boiler room was next door).
    When i was a second year apprentice i tried to vacum up some with a shop vac,great learning experience.whistle1
    Mesquite Tx.
    I have used the heaters lots. They don't have any fusing so it is kind of spooky. But you can't beat a boiler. You gotta make sure you don't go too fast. Once heated a CVHE500 with R-11 to 8 lbs in 2 minutes. Scared me I thought it would get the rupture disc before I got it shut down. The stress coulbn't have been good for it. We converted it later, that was 15 years ago, I think it is still running.
