    Oct 2006
    Central Texas
    RTHC Cold filter line fitting
    Got one for you guys who have replaced the 5/8 steel line to copper. From the cold filter line to compressor housing, there is a fitting looks to be compression style or roto-lock? Parts breakdown not real clear, priced new nut, adapter, & sleeve. Inspected job for bid, machine still under pressure, a little unclear on how this makes up. Thanks.
    Sic Semper Tyrannis.
    Apr 2004
    Winnipeg,MB,Canada
    ORB
    The fitting you mention is called "o-ring boss" or ORB. It allows you to thread the fitting in to the position you want, then you tighten the nut down, squeezing an o-ring into a bevelled seat. I like to use a little Nylog on the o-ring, keeps it from pinching or rolling.
    Nov 2007
    I am unsure myself
    There are two parts to that fitting one needs to be silvered onto the end of the copper and the nut is a separate part no. I just replaced a couple during a overhaul and I know the end piece is a adp?????. Pretty simple repair fyi
    Oct 2006
    Central Texas
    Thanks for the responses, like I said the parts break down don't even show the part... it just lists a nut, adapter, & sleeve. I figured it probably soldered on... nothing a little silver can't fix, thanks again.
    Jan 2015
    Somewhere making cold water
    I have replaced those lines and all others that were steal down to gas pump. Seems that I remembered parts difficult to find, believe they were with rnewl parts.
    Jan 2011
    NICE! Dragging up a six year old thread. I wonder if that's a record.
  7. Likes jayguy, r404a liked this post
