Results 1 to 13 of 18
    Jun 2009
    External Static Pressure Question
    My return static:
    before filter -.10
    after filter rack, in blower compartment, with no filter in place -.15
    with filter (cheap blue fiberglass) -.35!
    Why in the world does my drop over a cheap blue fiberglass filter go as high as -.20?? I'm using a magnehelic 1.0 wc pressure guage with a probe. I'm inserting the probe in a preexisting hole on the side of the blower compartment.
    The supply static before coil is .35, so my total ESP is .70.... But, I'm still puzzled by why the filter is causing so much pressure. Could it be that I'm putting the probe in the most turbulent part of the blower compartment?
    Thats possible.
    Could also be the air filter is too small.
    Jun 2009
    Thats possible.
    You're probably right about the filter being too small. The contractor told me to use a 20x20, but a 15x20 would cover the opening to the furnace.
    Is it normal for there to be a pressure drop after the filter rack even without a filter in place? I have a drop of -.05 even when there is no filter... is that one of the signs that the opening is too small?
    Opening tpp small.
    Turbulance where your measuring.
    Either one.
    Jun 2009
    Opening tpp small.
    Either one.
    Would you suggest drilling a hole in the middle of the blower door to get a more even measurement?
    SW Wisconsin
    I had a reply ready to send & the power went off.
    So, this will be short.
    What tonnage & CFM are we talking about?
    Is there a knockout to use a larger filter?
    Beenthere answered your questions.
    A manual D might be advisable.
    It apparently needs more filter area!
    Probe areas - use your own judgment. - Darrell
    AOP Forum Rules:
    Rules for Posting
    Rules For Equipment Owners
    Equipment Owners Find a Contractor HERE!
    Free online whole house load calculator & Sizing: http://www.loadcalc.net/ Anyone can use it...!
    udarrell
    Nov 2005
    India
    Check velocity across filter if it higher than 400-500 feet per minute then also static will be high.
    Quote Originally Posted by david8370 View Post
    I don't suggest any DIY actions.
    Jun 2009
    Thanks guys.
    Jun 2009
    Quote Originally Posted by udarrell View Post
    Thanks udarrell. There is actually about 2 inches more of knockout on the side that the contractor did not open because the return duct was not wide enough. I guess I'm kind of screwed for now until I can afford to get my return duct modified.
    Jun 2009
    I hear ya, man. Thanks.
    Apr 2008
    Princeton, NJ
    Post 44 in the attached thread links you to a video illustrating static pressure testing.
    Key1
    http://hvac-talk.com/vbb/showthread....light=upstairs
    In the land of the blind.....the man with one eye is king....
    Jun 2009
    Hmm
    Quote Originally Posted by key1cc View Post
    Key1
    Thanks Key1. That's the video I initially used for guidance. The only difference is that I put the probe on the side of the blower compartment through a hole that already exists instead of in the middle of the blower door. Wonder if the location makes that much of a difference.
    In the video, the guy says to put the probe 90 degrees to the airflow, but I've also seen where the instruction is to put the probe pointing into the airflow... which one is correct?
    I realize this is a bit DIY, but, in fairness, I've had 2 different contractors out who didn't know the proper way to measure static pressure.
