Results 1 to 13 of 13
    CA
    Sampling static pressure
    Does anyone have a good diagram or easy explaination on where to take static pressure readings on an RTU? The question is geared toward the return side....is your TSP referencing before or after the draw through coil?
    BDP 588ANW060100
    http://www.docs.hvacpartners.com/idc...i588a-18-9.pdf
    http://www.docs.hvacpartners.com/idc...588a.18.4b.pdf
    Jun 2001
    Louisville, KY
    The blower performance chart is using External Static Pressure (see pg. 41 of your first link).
    I would punch wholes in the duct next to the unit if it's a horizontal discharge.
    If it's vertical discharge, I'd punch wholes in the horizontal duct connection panels.
    If you wanted to use the wet coil pressure drop table on page 44, you'd punch holes in the blower access door and the return panel/duct.
    Merry Christmas
    Home of the newly wed and the nearly dead
    Total Static Pressure is fan discharge static-fan suction static.
    External Static Pressure is supply static-return static
    If the fan discharge static is 2" w.c and the fan suction static is -1", the fan's TSP would be 3" (2"-(-1")
    CA
    thanks!
    Quote Originally Posted by BergerMech Rob View Post
    this diagram is one of the best explanations that i have ever seen!
    thanks!
    The weak aren't destroyed by the strong.
    The weak are destroyed by the under-estimated.
    I know a famous song that ends in 'my nose'. The artist is dead. Know who?
    Glad I could be of assistance.
    Jun 2009
    thanks.
    thanks for the diagram
    THE MORE I LEARN
    THE MORE I FIND I DON’T KNOW
    Cancer Survivor
    And Dam Well
    Plan On Staying That Way
    BR,LA
    Static Pressure (Sp) This is pressure that is exerted in all directions of a duct. When static pressure = total pressure there would be no flow.
    Velocity Pressure (Vp) The difference between total pressure and static pressure.
    Total Pressure = Static Pressure + Velocity Pressure.
    Jul 2009
    Good diagram can somone also diagram this for an AHU with a SF and a RF
    I modified it a bit to show a little more detail and now it has a supply and return fan.
    Jul 2009
    Ext SP
    Thanks for the new diagram with the SF and RF. Thats about what I figured. But the reason I wasn't sure is becuase on the Fan shcedule ( on the plans) it has a design ESP for each fan. ( SF & RF ) while I would expect to see a design TP for each fan I thought I would only see one ESP for the AHU not the way they have it...so i'm still a lil confused...but thank you for confirming what I thought...Noel
    Quote Originally Posted by Noelcon View Post
    I don't see how you could have more than one ESP for the same piece of equipment. I'd put in a request for information to that engineer, and maybe he can put a good word in for you with his dealer
