Results 1 to 7 of 7
    Aug 2009
    Confused mini split ratings
    I'm am choosing minisplits for my home near Cuernavaca, Mexico. I have four brands available: LG, York, Trane, and Mitsubishi. I can't find comparative ratings for these brands? Do such ratings exist?
    Aug 2009
    Each manufacturer will typically have ratings on their spec sheets. Also, you can look up ratings on AHRI's directory of certified products, which is here: http://www.ahridirectory.org/ahridir...ages/home.aspx
    It is helpful if you have the model numbers of the units you want to compare. For standard single speed mini-splits, look under the air conditioner or heat pump category. For varible speed mini-splits, there is a separate category to check.
    Jun 2001
    DFW
    Find an HVAC contractor with minisplit experience in your area - ask him which one he recommends. The best system is one that has qualified people to install and fix any problems that crop up, and with good support from the manufacturer in your area.
    Feb 2007
    Quote Originally Posted by Guillermo View Post
    Mitsubishi is my pick, I use them often.
    If it doesn't go easy, you are not using a big enough hammer.
    Mitsubishi is a good pick as well as fujitsu. Both are very quiet and efficient
    100th post....woo hoo
    Mitsubishi Electric is the pick of that bunch.
    There is also a brand known as Mitsubishi heavy industries, which is no where near as good.
    Jul 2009
    Fort Worth, Texas
    Trane's data is easy to find.
    http://www.trane.com/COMMERCIAL/DNA/View.aspx?i=1129
    Here is Fredrichs
    http://www.friedrich.com/products/Li...ls.php?line=SZ
    I have many happy customers that have the Fredrich's.
