Results 1 to 13 of 24
08-12-2009, 10:46 PM #1
- Nov 2007
- 44
Static pressure on infinity control
What is a good pressure on the control? I have a 4 ton unit. It is a carrier split system with a 96 gas furnace o infinity control.
08-12-2009, 11:17 PM #2
- May 2009
- 196
08-12-2009, 11:25 PM #3
- Nov 2007
- 44
My static pressure in high is around 0.66. Guess I'm OK
08-12-2009, 11:29 PM #4
- Nov 2007
- 44
Helping pressure
what should I do to improve the pressure?
08-13-2009, 06:05 AM #5
Professional Member*
- Nov 2004
- SW FL
- 5,355
A Few of many Air Flow Optimization Hints
Smooth duct transitions are nice to the air.
Kinks can sometimes be easily eliminated.
Use manufacturers WYE's instead of on-site fabricated junctions made from insulating board (a.k.a. duct board).
Record overall static pressure with a NEW filter (hopefully about 0.5") and when the pressure is increased by about 0.2" (0.7" total), it is time to replace the filter.
Do not use higher than a MERV 8 1" pleated filter. MERV 6 is sufficient.
Or use a 5" filter so that filter replacement is less frequent ( perhaps annually with 5") and initial resistance is minimal.Designer Dan
It's Not Rocket Science, But It is SCIENCE with "Some Art".
08-13-2009, 06:17 AM #6
- Nov 2007
- 44
wierd system
This system had a temp of 68 in one room, and 71 in all the rest. That one room is the biggest in the house with 3 vents and around 670 sq ft. Strange system.
08-13-2009, 10:19 AM #7
- Feb 2008
- Dallas & Longview, TX
- 627
Strange but good. Have a tech come out and measure the static supply side vs. return. It the return is restrictive, add more filtration or ducting according to need. If high on supply side then add ducting refinements to lower it a bit.
Once you have it perfected or even if you leave it as is, you still have room to adjust dampers to balance the airflow. Airflow adjustment will increase the static and could create noise issues if the static is to high.
You may have enough room to balance the airflow without changes so you will need a good tech that has experience with this. I assume you have a 4" filter but if not I'd add it regardless.
08-13-2009, 08:33 PM #8
- Nov 2004
- SW FL
- 5,355
Money and time will solve it !
Designer Dan
08-13-2009, 11:04 PM #9
Banned
- Aug 2002
- Office and warehouse in both Crystal River & New Port Richey ,FL
- 18,836
08-14-2009, 01:31 AM #10
- May 2009
- 196
08-14-2009, 06:13 AM #11
- Nov 2007
- 44
Large ducts
The 3 vents to the large room are 8 inch and the rest of the house are 6 except for the large great room upstairs. it has 10 inch split into 3 upstairs.
08-15-2009, 12:52 PM #12
- Nov 2007
- 44
infinity thermostat
Does anyone have any idea what operating system thie unit uses to control itself? windows, linux, etc?
08-15-2009, 02:44 PM #13
- Feb 2008
- 627
Most things like this use a version of linux. Not sure though but not MS for sure. You planning on hacking into it?
