Results 1 to 11 of 11
    Aug 2009
    New fan, new capacitor, new contactor, still problems
    After generic (Heil) condenser overheating capacitor, I replaced Cap 36uF, 3uF 370V with a 36uF,3uF,440V, but fan made a terrible noise, so I replaced the fan w/OEM fan motor. Still made noise, but after hitting contactor, everything ran quiet and the compressor started OK. I let it run for 4 hours; no overheating, no problems, and the house cooled down 10 degrees, but I knew I still had a problem. This morning I replaced the contactor block, but the fan noise still happening, only this time I can't stop it by hitting contactor block. The motor begins to heat up very quickly after about 1 min.
    Could this be from the extra V setting on the cap.? Do I need to recheck all my connections (again)?
    Oregon
    Quote Originally Posted by GeraldScottster View Post
    No
    Aug 2009
    Any other ideas? Could the capacitor be bad? Since I didn't change the first fan immediately, could it have damaged the capacitor. I don't have the expertise to check running amps, volts, etc, but it sure seems the fan is not getting enough power
    Oregon
    Sorry, but the moderator will likely tell you that you need to join the pro forum to get a more detailed answer to your question.
    The only thing I can say is double check everything. You didn't by chance jumper the 36uF tap to the fan and the 3 uF to the compressor?
    May 2009
    Earth
    You need to call a pro before you get your self hurt or killed.
    Aug 2009
    I've got one last thing to replace; the fan blade. Another person told me the hub could have been damaged by the overheated fan motor. The noise definitely comes from the fan and sounds like the blade. I just assumed it was OK. I'll post the results.
    keep on scooter............you get it rebuilt
    change enough parts and you might get it fixed
    did you bother to read the RULES
    Ohio
    Sounds good....we like results....
    I need a new signature.....
    Apr 2005
    N. E. Missouri
    What does the noise sound like? Maybe you should get us a video. If it's a pleasant noise you could just leave it (crickets?) or if it's got a beat maybe neighborhood kids can dance to it...
    Seriously, you haven't a clue what you are doing and may have made yourself a much more expensive proposition for a pro!
    Do not argue with an idiot. He will drag you down to his level and beat you with experience.
    Jun 2001
    Louisville, KY
    No Do-It-Yourself here.
    Thread closed.
    http://hvac-talk.com/vbb/showthread.php?t=186644
    Feb 2005
    Miami, Fl.
    They can post them somewhere else, not here.
    Rules...............
Tags for this Thread
