    Aug 2009
    refridgerant line
    I have been told I cannot install a 16 seer system on my second floor because it has a two stage compressor and the refridgerant line is greater than 25 feet. I was told it cannot be this high. Is this correct.
    Chicago, IL
    If you mean the condenser sits on the ground and the furnace/air handler is above it on the second floor, then there is no problem with having a two stage unit.
    If the condenser is above the air handler or furnace, then there may be issues with oil return depending on vertical distance, lineset size, and length.
    Feb 2005
    Barrie, Ontario
    A trained mechanic won't let a little thing like oil lift hold him back...
    Amateurs, just amateurs.
    Is this a Fabreze moment? C.Y.D. I'm voting white elephant. 2.
    Call another contractor.
