Results 1 to 13 of 14
    Aug 2009
    Eastern Panhandle WV
    Standard wiring for thermostats
    Is there a standard wiring code for thermostats as far as the colors of the wires as to what they go to? I have seen several wired completely different.
    Thanks.
    If you couldn't tell I am new to this.
    Lancaster PA
    Not really a standard.
    After your accepted to pro membership. You can ask technical questions in the pro forums.
    Colorado flatland native
    Yes.
    and No.
    It depends. You in the biz? Who the hell is training you?
    Walter Matthau
    Jul 2001
    If you are color blind it doesn't matter. The ability to ring your wires helps greatly.
    Quote Originally Posted by troyorr View Post
    Like a telephone??
    Walter Matthau
    Houston, Texas
    Quote Originally Posted by spotts View Post
    Like a telephone??
    I thought like this.
    Jun 2008
    Cincinnati, Ohio
    Colored wires? Really????
    Jul 2001
    That record is turning backwards.
    Houston, Texas
    Not for that year juke.
    Toledo, Ohio
    Twilli says WV.....give him break
    No Heat No Cool You need Action Fast
    Jul 2001
    Spotts, yes, same procedure. Useful when you are the only one on a multi-storied job and you have to figure what wires go where.
    Jul 2001
    The "groove" in a record is cut so the stylis travels inward as the record turns clockwise. Running backwards, the needle will be deformed and act against the groove. How is the tonearm constructed on that model? Every jukebox I've seen, and you know I am an expert, shows the record turning clockwise. Wait, in Australia they may turn counterclockwise wise, like toilet water when flushed.
    NC Coast
    the arm is on the wrong side . It would be going against the groove..... you know... pushing the needle into the record.... not allowed to slide with the groove!
