Thread: best method
    Aug 2009
    Eastern Panhandle WV
    best method
    I have to set a self-contained A coil in an existing system and run line set and thermostat wire to out door unit. I am wondering what is the best way to mount the coil. I am thinking of mounting it on top of the return box. It is a verticle airhandler. I don't guess it has to be on the supply side for any reason does it?
    Also what is the best method for mounting the filter to it? I was going to mount it right on top of the coil in the return line. Are these acceptable methods. This guy got a used 3ton Colman and matching coil and wants me to help him install it into his duct work. I have not had much experience in sheetmetal work. would it be ok to make the transition using duct board? This guy wants to spend as little oney as possible. He doesn't even want the outside disconnect used, just wire it direct.
    Thanks in advance.
    Howell, Michigan
    These types of questions are for the closed "Professional Forums"
    There is a link in my signature line for Professional Membership. You need 15 posts to qualify.
    You don't have the experience to be doing this by yourself.
    Get your post count up to 15 and follow the link in bob's sig.
    Thread closed.
    Feb 2005
    Miami, Fl.
    Wow,
    You really didn't read the rules of this site did you?
    This thread is closed.
    Howell, Michigan
    LOL...............I beat both of you for once!
    Quote Originally Posted by HeyBob View Post
    LOL...
