    Jun 2009
    Rheem RGRL Gas Furnace
    Well, it was cool enough today, so I tested out the furnace for the first time. The low fire is coming in at a temp rise of about 30.. the spec range is 25-55, so it's a little low, but within range. When it kicks to high fire, it only gets to a temp rise of about 41, with a spec range of 35-65 and then the burner kicks off without the thermostat being satisfied. There are no error codes indicating limit being open, so what else could possibly be causing the burner to shut off before thermostat satisfied? I checked the combustion and exhaust flues and they are clear.
    Apr 2004
    First thing is first...
    Use a jumper instead of a thermostat. You'll know in a hurry if it's something in the cabinet or in the control circuit.
    Jun 2009
    Quote Originally Posted by docholiday View Post
    Turns out it was open limit. I finally figured out the blinking light codes. I reset the breaker and seems to be fine now.
    I don't know
    The real question is which limit opened, and why?
    The problem will most likely recur
    Jun 2009
    Quote Originally Posted by amd View Post
    I think it happened because I had pulled the limit to test the static pressure using that access hole. Must have tripped it.
