Results 1 to 13 of 28
Thread: cheaper to operate
08-08-2009, 10:36 AM #1
- Feb 2007
- pa
- 41
cheaper to operate
is it cheaper to operate a 13 seer 3 phase ac unit compared to a 13 seer single phase ac unit considering all things are equal such as run time, voltage, etc. i am not looking to count pennies by factoring in startup draw, but on the whole, is there much difference. thanks, john
08-08-2009, 10:55 AM #2
- Jun 2003
- 3,633
both units will cost the same to run. The 3 phase unit will cost more up front, but will generally be more reliable (contactors last longer and there is no compressor capacitor or start relay)
08-08-2009, 10:57 AM #3
isnt the amp draw on the 3 phase less than the single phase?
08-08-2009, 11:15 AM #4
- Feb 2007
- pa
- 41
yes, 3 phase is 17 rla, 1 phase is 26.3 rla
08-08-2009, 11:22 AM #5
08-08-2009, 11:26 AM #6
- Jul 2009
- Plant City, Florida
- 2,198
08-08-2009, 11:28 AM #7
08-08-2009, 11:30 AM #8
08-08-2009, 11:46 AM #9
- Jul 2009
- 2,198
An American Standard TSC060 13 SEER 3 phase 480 v RTU has a max breaker size of 15 amps.
An American Standard TSC060 13 SEER single phase 240 v RTU has a max breaker size of 40 amps.
Which one draws more amperage?
3 phase power is always cheaper to run equipment than single phase.
08-08-2009, 11:50 AM #10
- Jun 2003
- 3,633
08-08-2009, 11:52 AM #11
Your not charged by the amp.
Your charged by the KWH.
Max breaker size has absolutely nothing to do with what it cost to run a single phase, or a 3 phase unit.
BUT. In your example, if they did run at max breaker amperage.
The single phase would use 9.6 KWs per hour.
And the 3 phase would use 12.456KWs an hour, costing MORE then the single phase.
08-08-2009, 11:59 AM #12
- Jun 2003
- 3,633
And a 6 cylinder car ALWAYS gets better milage that the V8 version
If you have two identical motors but one is 3 phase and one is single, the 3 phase motor will be cheaper to run. However, we are not talking about motors, we are talking about A/C SYSTEMS. A system consists of more than just motors. The single phase unit may have larger coils to lower condensing pressures meaning a smaller compressor can be used in the single phase unit but have an equal capacity to the 3 phase unit. A more efficient refrigeration system is used to make up for a less efficient motor.
Beenthere said it best "If it was more efficient it would be more than 13 SEER"
08-08-2009, 12:12 PM #13
Like Beenthere said you are charged by KWH.
If you increase the voltage the amps drop, however Kilowatts are calculated by this formula
Volts x Amps = KW single phase
Volts x Amps x 1.73 = KW three phase
So you figure it out. Double the volts and the amps are half, but 6 is still a half dozen and when you change from single phase the breaker size changes because you are carrying current across more conductors. It's like trying to put 100 cars down a two lane or three lane road. You still have a 100 cars but less per lane.
In the industry 3 phase motors are cheaper to operate, because they typically have higher efficiencies and are higher torque on startup which will reduce the initial amp draw spike.
What determines money savings is the utility companies charge per kwh for single phase services versus three phase. Three phase may be cheaper because it's more of a commercial/industrial service in some areas and they expect a higher usage so they reduce cost per kwh.
Installation cost for higher voltage systems is typically lower because smaller wire can be used. Smaller wire = smaller conduits = easier and cheaper install. The equipment maybe a little higher in cost which means you might not have saved anything.
