Results 1 to 11 of 11
Thread: 5 ton ac
    Sep 2006
    TEXAS
    5 ton ac
    service call was unit not cool, (but the house is cool not enough but it is cool), unit runs all day and night, never turns off.
    set gauges low of r22, cut coil and washed coil, coil dirty.
    soldered coil back to unit, opened valves done, so i thought got a call back still doing the same thing.
    ruud unit
    md#uamb-060jaz
    split system
    subcool
    psi-250
    temp-118 liquid line temp @ evap coil-27.5
    superheat
    psi-64
    temp-35
    suctionline temp-73 (6-8 from compressor).
    any ideas guys really need the help thanks.
    We'll be glad to help - but: need to get yourself promoted to professional member so we can move this thread behind closed doors. Site rules don't allow technical discussion here. You need 15 posts, so post a few more, try general or food maybe and apply for your pro membership.
    Sep 2006
    TEXAS
    thanks will do, 15 not a bad number.
    Aug 2009
    I'm in the same boat...13 to go (12 if you count responding to my own thread, not sure if that counts).
    Quote Originally Posted by smurry View Post
    It counts.
    Sep 2006
    What time is it there in Houston? (this should make you at 15)
    Sep 2006
    TEXAS
    guys in a world of hurt thinking its the txv, but would like to hear your opinions as well thanks.
    SW Wisconsin
    Arrow Guess is, Hot Air leak into Return & Low R-22, ha
    Quote Originally Posted by dads View Post
    ruud unit
    md#uamb-060jaz
    split system
    subcool
    psi-250
    superheat
    psi-64 is SLT 73 -37-SST = huge 36-F Superheat
    temp-35> 64-psig is 37-F
    Well, 36-F is a lot of superheat, also there is no Subcooling, therefore there's either not enough liquid refrigerant entering the coil or you have a huge hot air leak into the Return-Air system.
    Could be a combination of both, hot air source leaking into the Return & low on R-22. Just a guess... - Darrell
    Sep 2006
    TEXAS
    thanks bud will check, and will keep you guys posted.
    SW Wisconsin
    Also, data indicative of low charge, & several other problems.
    Apr 2004
    condesner (low subcooling) - not enough charge
    evaporator - (high superheat) not enough charge
    Where is it? Cant be hiding somewhere else.
    37 degree coil doesnt suggest a huge load on the system. Although I am confused how you measured 27 at the evaporator?
