    Aug 2009
    Question Carrier/Payne/Bryant Coil (CK5A06) with PA13 -- PISTON vs. TXV
    Here's the deal. We have a home that has a PG9M-06 with CK5A-06 5-TON furnace / coil. We are looking to pair the coil and furnace up with a "matched" condenser.
    The CK5A-06 coil shipped with pre-installed 90 piston and it seems like a Payne PA13 condenser will be a nice match.
    The question:
    The CK5A is a 13-Seer Coil and can use both R-22 and R-410a (when used with a Puron TXV). The coil currently has a 90 piston. Can we just use the installed 90 piston with a Payne PA13 and call it good? OR do we need to use a R-22 TXV? Any other condensers you'd recommend for this furnace/coil combo?
    Thanks.
    Nov 2007
    Alabama
    I'd definatley go Txv kit. Much better metering of the refrigerant.
    May 2009
    South of Heaven
    Quote Originally Posted by bdw293 View Post
    That is as " safe " as it gets for certain , lol ( like " the sky is blue " ) . Get them to " throw in " a hard start kit while someone is going through the trouble.
    edit : use the txv kit per manufacturer's instruction for your system ... as not to be " Captain Obvious ".
