Results 1 to 6 of 6
08-03-2009, 03:56 AM #1
- Jul 2009
- 18
Carrier heat pump air temp and other questions
Hi, all. We will likely be going with a Carrier solution now for our furnace replacement, and we are considering a solution that would pair the Carrier ICS furnace with a Carrier Infinity 16 or 19. I'm having my doubts about this approach and am hoping you regulars can help -- especially those of you who know Carrier equipment well.
My questions:
-- Coupled with the Carrier ICS, would the Infinity 16 and 19 deliver heat at roughly the same air temp coming out of the ducts? The 16 uses reciprocating compressors and the 19 uses scroll compressors.
-- The Carrier dealer says the air temps from Carrier heat pumps are higher than with other heat pumps. Is this true? How much higher? What air temps can we expect? I'm concerned that we'll end up not using the HP to heat if the air temps from the ducts aren't pretty comfortable.
-- I know heat pumps generally run longer than furnaces and possibly with greater cfm. On a moderate heating day, is there a pretty high cfm going through the ducts a good bit of the day, so that it might feel drafty in some locations, or is the flow pretty low?
-- If well maintained, which they would be, are the two-stage HPs as reliable as the single-stage models (say, the Performance 15).
-- I'm considering the two-stage HP instead of a single-stage HP or A/C because the dealer says I'm much more likely to avoid big temp differences between the first and second floor of our home with a two-stage unit when in cooling mood. He estimates I could see a difference of 5 to 12 degrees (F) with a single-stage model but just a few degrees, maybe 3, with a two-stage model. Does this make sense?
-- The software the dealer uses predicts that I'd save about 50 percent with Carrier ICS and an Infinity HP relative to my current 80 percent gas furnace. Does this sound right to you? It seems a little optimistic compared to some of the online energy-savings calculators I've found. We pay about 10 cents per KWh for electrical and about $1.32 for natural gas.
Thanks for any help.
08-03-2009, 06:09 AM #2
- May 2009
- 196
Compressor type shouldn't make any difference provided the two units have the same output capacity.
Hard to say. The Infinity thermostat will vary system airflow to provide the warmest air possible from the HP. Maximum airflow should be about 350 CFM per nominal ton (e.g. 1050 CFM for a 3 ton unit) but how often the system goes to full air flow is up to the whims of the Infinity algorithms.-- I know heat pumps generally run longer than furnaces and possibly with greater cfm. On a moderate heating day, is there a pretty high cfm going through the ducts a good bit of the day, so that it might feel drafty in some locations, or is the flow pretty low?
Draftiness, however, will depend on the volume of your house and the quality of your ducting.
Even temperatures between floors are a matter of ducting and duct balancing.-- I'm considering the two-stage HP instead of a single-stage HP or A/C because the dealer says I'm much more likely to avoid big temp differences between the first and second floor of our home with a two-stage unit when in cooling mood. He estimates I could see a difference of 5 to 12 degrees (F) with a single-stage model but just a few degrees, maybe 3, with a two-stage model. Does this make sense?
Beware that you'll need either zoning or two separate systems (one per floor) if you want/need to keep both floors at the same temperature in all conditions.
Sounds unrealistic at first glance. Work the numbers to see what COP you'd need to cut your heating bills in half and compare it to Carrier's published performance data for their heat pumps.-- The software the dealer uses predicts that I'd save about 50 percent with Carrier ICS and an Infinity HP relative to my current 80 percent gas furnace. Does this sound right to you? It seems a little optimistic compared to some of the online energy-savings calculators I've found. We pay about 10 cents per KWh for electrical and about $1.32 for natural gas.
08-03-2009, 08:39 AM #3
- Apr 2009
- WV
- 75
My situation sounds similar. I ended up going with the ICS furnace and Performance 15 H model HP on my first floor. This will replace a gas furnace/A/C combo. It's scheduled to be installed so I can't tell you how it is working out. I researched it to death and found that the Infinity 16, 2-stage HP has worse numbers than the Perfromance 15 single stage HP. In my humble opinion, if you decide on a Carrier 2-stage HP, stick with the Infinity 19 solely on the SEER, EER and HSPF numbers alone. From what I can tell, the Infinfity control will vary the fan speed on the ICS furnace to control humidity during cooling even when coupled with a single stage HP.
My setup is for my first floor. When I replace my upstairs HP, I will probably go with the Infinfity 19 where the cooling load is greater.
08-03-2009, 11:57 AM #4
- Jun 2007
- The Twilight Zone
- 2,964
The Carrier dealer should be able to provide you with technical operating data for each heat pump that lists the air temp after the indoor coil (in both first and second stage) as well as SEER, EER, HSPF, and btu output over a range of ambient temperatures.
Tell him that you want to see the technical operating data.
Good luck.
08-03-2009, 12:05 PM #5
- Nov 2008
- 1,656
08-03-2009, 12:22 PM #6
- Aug 2009
- Kansas City
- 258
No heat pump on the market will match the air temp output of a furnace that I have seen. The carrier thermostat will look at outside temperature and outdoor coil temperature to decide on what cfm the indoor fan should run at. Carrier has the best controls in the industry. So this is probably why your contractor has made the comment about the warmer air. 2 stage units have longer run times which means more consistant temperatures throughout the home. The 50% savings may be optimistic, but it really depends on the insulation value of your home.
