Results 1 to 13 of 16
    Rochester, MN
    Record Cold July.
    Well, we wrapped up the 2nd coldest July on Record here in Rochester, MN.
    We had avg temp of 65.4˚ for the month of July. We have not run our A/C for the whole month of July! So far this summer I think I've ran our A/C for 5 days total, around end of June when it was warm, and pretty humid.
    I'm looking forward for our July's electric bill! ;-)
    Sad note, I've read in the paper that on HVAC dealer had 10 tech, and had to cut down to 4.
    Wonder what August will be like... Snow??
    southern illinois
    same here,2nd coldest july on record,...........it did this a couple of years ago,i have a feeling we better get ready for our turn for the heat like other parts of the country have been seeing.
    Grundy Co. IL
    It has been really wet here too, 7.88" of rain in July.
    Jun 2007
    The Twilight Zone
    Global warming?
    Jul 2009
    King Ranch Texas
    its been global warming here in south texas seeing 110' daily!
    Jun 2008
    Cincinnati, Ohio
    Our average temp for July was 70.2*.
    Calgary AB
    Average temp in BC has been about 30
    Quote Originally Posted by phbsales View Post
    Dont remind me
    Jul 2001
    Central MN and the Twin Cities
    Everybody is slow to just barely getting by. Nobody is hiring and there is still hundreds laid off around here. I really hope some things change soon.
    Warning: Just because I am over the head injury doesn't mean I'm normal!
    The day I stop learning.... I'm dead!
    Madison, WI/Cape Coral, FL
    Quote Originally Posted by grasshopper View Post
    Madison WI had a record cold July by 4^F. Must say dehu sales are good in areas where the the cooling loads are high. The outside dew points mostly 60-70^F which is high enough to make basements smells. I have dehumidifiying 200 lbs. per week to maintain 50%RH in the basement and 45%RH on the mainfloor. This is with 2 adults and 60 cfm of make-up fresh 14 hours per day. 6-10 hours cooling per week with 20 lbs./ week of moisture removed. Very comfortable and fresh. Calm winds and the loss of the stack effect reduces natural ventilation to little or nothing. Contractors should consider marketing whole house ventilating dehus.
    I am writing this from Joe's Summer Camp, Westford, MA (Building Science Corp). Had a day reveiwing building failures, the need for continuous training and blameless reveiw. It was invigorating. Build the home right the first time, correct ventilation, and keep the home dry are the issues. HVAC plays a critical part in this process. Most are dissapointed in our nationwide knowledge levels of processes, verification of preformance, and general followup.
    Many of us/you do care. Keep up the effort. Change is comming foresure.
    Regards TB
    Jun 2002
    Bemidji, Mn
    I dont think summer ever arrived... Which is fine with me, I love winter! Hows it going Grasshopper? Im somehow keeping myself busy enough up here.
    You picked a fine time to leave me loose wheel...
    http://rapalaguy.spaces.live.com/
    Fort Worth, TX
    North Texas July went back and forth. A week of 100+ weather followed by a week of partly to mostly cloudy, cooler weather, and rain. It's been wetter than normal, with unexpected breaks from the heat. A few hundred miles to the south, areas such as Austin and San Antonio experienced an ongoing bad drought and blistering heat.
    August has arrived, which typically means about a solid month of hot weather. This week has started off that way, for sure.
    Building Physics Rule #2:
    Building Physics Rule #3:
    May 2009
    Earth
    The part of NY I am in, 90 Miles north of NYC has not seen a day at or above the 90 degree mark since July 2008. I have never seen a solid year in this business where we ever had this kind of weather. The winter was steadily cold too, but I don't recall it getting below zero either. So the pattern is not extreme in either direction? Maybe the real predictors are right, the ice age is coming?
    http://iceagenow.com/
