Results 1 to 8 of 8
Thread: Insulation
    State College, PA
    Insulation
    Hi,
    I work for a HVAC Contractor and occasionally work with the Geo Install crew. I was wondering what you guys are using to insulate the ground water pipes. We seem to be spending a lot of time wrapping pipes.
    I just wondered if there was another solution other than Armaflex.
    Thanks in advance.
    Massachusetts
    We don't wrap the pipes. They're buried deep enough in the ground so there's little temperature variation between the well and the house.
    State College, PA
    thanks
    Our pipes are coming in the basement at about 3' below grade. How low are you coming in?
    Massachusetts
    We're about 8-feet down at the bottom of the foundation wall. At 3-feet we'd wrap them but we're never that shallow. But rather than wrap, we'd use rubbertex foam insulation that slides right on the pipe. It's got a talcum layer on the inside of the insulation that lets it slide right over the pipe. We use the same stuff on heating pipes of all types when doing conventional burnt air heat. Water pipes, refrigerant lines, whatever. We save the spit & sticky stuff for the last few feet if we can't push the non-split far enough down to make the final connection.
    State College, PA
    Yeh, thats waht we are doing now. Real PITA. Hoping to find a better way. Way thinking there must be some sort of spray foam or something.
    Oh well, was a happy thought.
    May 2009
    northern kentucky
    Are you putting the armaflex on before fusing the pipe? I can't think that there is anything easer than sliding it on, hooking up the pipe and then gluing the insulation.
    State College, PA
    Thanks for the reply local,
    Yes, the piping is getting insulated before fusing the pipe. The real issue is insulating the pipe at the manifold at the entrance of the pipe into the basement. A real PITA.
    Baltimore
    Nomalock type insulation works ok.It always sucks having to insulate in the ground.Most jobs didnt need it as we were 3 feet or lower at the manifold or where the pipes enter the foundation.Sometimes I would use a straight length of 2"sch 40 pvc with a 2x1 1/2 fernco fitting on the end and slide the pipe through.
