Results 1 to 10 of 10
    Dry as a bone Tucson
    How to choke a heat pump, Phoenix style.
    The supply and return are split in the middle where the screws are.The return starts on the far left side of the duct.
    Here is what it looks like inside the unit. The clear opening dimension is 7"x18". This is a 5 ton unit. There is a 20x30 filter grill in the house.
    notice the rust from condensate sitting. The condensate only drains when the unit shuts down.I didnt have my magnahelic this day but you can bet that the static was well over 1".
    Watchman Nee
    Feb 2007
    Las Vegas,NV
    I see they set the unit sideways on the roof, must have been an over/under unit there at one time.
    Some of those over/under setups had small returns, I see alot of those around here.
    over/ under
    your exactly right, probably was an old Goettel (one tough old unit )with a marginal duct design and install. Who ever came up with over under ought to be shot.
    Watchman Nee
    Feb 2007
    Las Vegas,NV
    Quote Originally Posted by ACFIXR View Post
    I see some really bad changeouts here. The worst is when they take out an over/under and mount a big ass unit downshot over the existing roof jack. Sometimes they end up with a hugh transition and the unit is standing 2 or 3 feet adove the roof.
    I prefer to just cut in a new properly sized return and switch everything to normal side by side setup.
    down shot
    I like to set a curb over the old duct and cut all the old crap out and redo it. Most people dont like curbs on resi but it gives you the opportunity to upgrade to better air delivery,and very happy customers.It is a lot of work tho.This is from a few years back.
    Watchman Nee
    Apr 2003
    California
    very nice, be proud....that is a big ass disconnect?
    houston, texas
    You forgot to remove the yellow sticker
    I'm not tolerating Political Correctness anymore, from now on it's tell it like it is.
    Veto Pro Pak - The best tool bag you'll ever own
    Big ass disconnect
    Quote Originally Posted by dave82323 View Post
    Our codes here require a dual disconnect for heat pumps with strip heaters, one for the unit and one for the strips.Single feeds are not allowed.
    Watchman Nee
    Outside The Motor City
    Quote Originally Posted by Texas-Tech View Post
    It said it is to be removed by the consumer, kinda like the mattress tag. LOL good work to letter of the law. a rarity today!
    flashing questionable
    Yellow sticker
    Yeah, but if you look real close it aint all done yet.
    Watchman Nee
Tags for this Thread
