Results 1 to 11 of 11
Thread: Smelly a/c
    Jul 2009
    Central a/c smells
    When our whole house a/c unit runs, there is a slight, but bothersome sewer gas smell in the house. We first smelled it only in the upstairs bathroom, but now seem to smell it throughout the house. I suspected it originated in the basement, but when I go down there, I don't seem to smell it. Any suggestions? It has gotten worse as of late. Does this seem like an hvac problem, or a plumbing problem?
    Thanks in advance!
    Mike
    May 2009
    Muncie, IN
    Your condensate drain may be tied in to your homes drain system without being properly trapped. That's the first place i would look.
    May 2009
    A leaking plumbing vent in the attic could be the source of your smell.
    Jul 2009
    So, do I call a plumber, or an hvac guy for this trouble?
    May 2009
    Muncie, IN
    I would call the hvac tech first. He should be able to determine your source of the smell.
    Jul 2009
    I agree with the poster that said to 1st look for a busted or simply not installed trap on the drain line.
    Jul 2009
    I think I will have a professional look at it.
    Oct 2006
    Georgia
    Quote Originally Posted by mocall7000 View Post
    Thanks in advance!
    Mike
    Is this bath used by any chance? If the tub or sink is not used you probably have a dried out trap, happens alot in houses that do not use the upstairs bath!
    <*}(((-< Good work is not cheap!
    >*}(((-< Cheap work is not good!
    Jul 2009
    I have a shower that is not used in that bathroom. The bathroom will be remodeled in the fall, and it has not been used for a couple of years. I poured water down the drain after reading about the possibility of the trap being dry. So far, no stink! My fingers are crossed. Thanks for the replies, all!
    Oct 2006
    Georgia
    That is definitely your problem then. Make sure you keep water in the tub, shower and sink traps and all smells should leave for good!
    Jul 2009
    Quote Originally Posted by fishnfool View Post
    That was excellent advice.
