Results 1 to 13 of 18
    Jul 2009
    North GA
    effects of altitude
    I live and work in georgia.
    vacationing in Denver colorado with family.
    his unit is freezing up, coils clean and filter unit is a 5 ton lennox with txv metering.
    with the change in altitude what difference should I expect to see with pt relationships and psig.
    water boils at 94f rather than 120f
    Urbandale IA. USA
    Altitude affects what is OUTSIDE the system, not what is inside.
    It will affect how fast moisture evaporates.
    Those who dance, appear insane to those who do not hear the music.
    Those who believe, appear ignorant to those who do not know God.
    Jun 2009
    Florida
    Quote Originally Posted by cehs View Post
    And how much air the fans move with each rotation. Lesser air density.
    Low Pressure Forever!
    If you know heavy metal, you can work anywhere-Dave Andreson
    Anchors Aweigh my boys, Anchors Aweigh!
    Farewell to foreign shores, We sail at break of day. Through our last night on shore, Drink to the foam. Until we meet once more. Here's wishing you a happy voyage home!
    Mar 2009
    Several Miles from Sane
    Quote Originally Posted by ChillerWisperer View Post
    Not to mention the fact that your gauge manifold guage PT scales are no longer accurate, you have to have an altitude compensated/corrected PT chart. Remember that at 5200' the atmospheric pressure is NOT 14.7 PSI it is in the range of 12.2 to 12.7 PSI, can't remember exactly.
    Fans and gas fired appliances have to be derated by 4%/1000' of elevation or roughly 16% in Denver.
    As stated what happens inside the system is not affected however without altitude compensation the equipment used to measure what is inside the system is not correct. An example would be a standard guage "Blanks off" at around 24" of Vacuum at this altitude where it will read down to about 28" of Vacuum at sea level.
    If sense were so common everyone would have it !
    Any advice provided is worth exactly what you paid for it, not a penny more not, a penny less !!
    in my lumpy chair
    RH is be lower so pressures are lower, check airflow, superheat and subcooling
    I dont warranty Tinkeritus
    Mar 2009
    Quote Originally Posted by Robert Shumate View Post
    I hope you ment 194* F and 212* F for the boiling point of water. Just an observation.
    New Mexico
    Not really. A cubic foot at sae level is the same size at altitude just less dense. A fan rated at 2000 cfm will move the same 2000 at altitude only will require less hp and won't be as efficient with transfer of heat.
    About the pt ? an example of r22 at 30 degf at sea level would be 54.9# at 5000 feet 30 degf would be 58#.
    There are charts available from supply houses here.You might Google it too.
    Like CCIKelly said almost everything measured at altitude needs to be compensated.
    I should have played the g'tar on the MTV. MK
    You can be anything you want......As long as you don't suck at it.
    SMW Lu49
    Apr 2005
    N. E. Missouri
    Quote Originally Posted by CCIKelly View Post
    Yeah, my water heater is set at 120 and it's not boiling yet!
    Do not argue with an idiot. He will drag you down to his level and beat you with experience.
    in my lumpy chair
    Boiling point of water
    F C
    sea level 212 100
    2000' 208 98
    5000' 203 95
    7500' 198 92
    10'000' 194 90
    15'000' 185 85
    It don't line up like the message shows
    in my lumpy chair
    Quote Originally Posted by mrs reb77 View Post
    Good lord Mrs... recalibrate your PSIA
    Jul 2009
    North GA
    thanks
    Yes I did thank you. I meant 194 not 94
    Jul 2009
    North GA
    Thank you all. I get it now. No need to insult. Those that did not, thank you for your help. I understand the adjustments needed. I know that inside will not be affected its outside that will be affected.
    Jul 2009
    North GA
    and yes I did mean 194f and 212f not 94 and 120. inebriated with family at the time of posting.
