    Outside The Motor City
    10 Ton water vacuum
    This is what happens when you install a 10 ton RTU with 1 - 12"return,
    They could not figure out how it would only leak water only so often into the building, they removed the economizer 3 years ago thinking it was leaking.
    I just got lucky enough to see it suck the water up through the fresh air hood like a water spout even luck to get a little video
    having trouble attaching video, it was taken with a digital camera as a .MOV file. whats the best way to attach it?
    Jul 2000
    Dallas,Texas
    There is no provision for attaching videos. Your best bet is to upload to YouTube or something like that and then link it here.
    Kc
    18" flex is only good for 5 tons isn't it?
    Metro Atlanta
    if i recall 18" round is good for 3 tons. 6"=1/4 of a ton 8"=1/2 10"=1 12"=1 1/2 . This is all for residential based on about .8 in wc. Commercial is different because you have more static pressure and cfm's. if im wrong please enlighten me!
