Page 1 of 4 1234 LastLast
Results 1 to 13 of 50
    Jul 2002
    NorthEast
    Honeywell Care Engineering software
    Does any one know where I can get an instruction manual for the
    "Honeywell Care" software for the the Excel controlers?
    Their website was not too helpful.
    Thank you
    Jan 2002
    Fort Worth\Dallas, Texas
    Care is a great programming tool and it is pretty easy to pick up on. It is when you have to use it in conjunction with LNS and SymmetrE (EBI) that things become a little more difficult.
    You just have to know where to look on the Honeywell site. Here are some links to get you going.
    http://customer.honeywell.com/techli...0s/74-5587.pdf
    http://customer.honeywell.com/techli...0s/74-3556.pdf
    http://customer.honeywell.com/techli...0s/74-5577.PDF
    If you have any questions my email is in my profile.
    Go Rangers!
    Jul 2009
    what u need exactly
    Jul 2002
    NorthEast
    Thank you, very helpfull links.
    What I am trying to do is get a very qiuick brief overview of
    !1 How to connect to the controller
    2 How to open the software
    3 Do i work in a graphic window ,likw the GX-9100 tool, or strictly with the Icon boxes
    ultimately I would like to
    -connect and open the software
    _make on a very simple application such as
    -a temperature sensor connected to a PID control which is controlling
    a Valve
    Thnak you
    Jul 2009
    1- you connect to the controller i.e Excel 500 thourgh RS-232 serial and there is an icon connect (you should have configure your connection com 4 or 3 ...).
    2- care is easy software , so you should configure the plant and the controller and later programmin.
    3-I don't know GX-9100 , but you do in Icon boxes , but when you do logic programming you need to make yourself.
    if you have the software I can send you some samples so you see it.
    Jul 2002
    NorthEast
    Everyone is very helpfull
    Yes please send me any samples you have.
    I have also been using the Lonspec disk
    I gather that Lonspec is a smaller version of Care
    I do not mean any disrespect to anyone, but I am
    use to the Tridium AX software.
    The CARE software seems less complicated to use.
    I do not know if it has the same tools the AX software has.
    Anyway, I like it very much
    Thank you
    Jan 2002
    Lonspec is nothing like Care, and personaly I would stay away from it and the XL15's.
    Just curious, if you are using AX why do you want to use Care? Are you going to be supporting some SymmetrE systems?
    Go Rangers!
    Jul 2002
    NorthEast
    I have a couple of sites with Honeywell
    Jul 2009
    Attached is care sample for 2 Valves and sensor
    http://www.4shared.com/file/12123326...5/HVAC001.html
    San Diego, CA
    Quote Originally Posted by komaher View Post
    .pjt above requires CARE 7.03.00 or higher (the latest I played with was 7.01.03)
    Aug 2009
    without CARE u can't learn so when u find it i will help u how to make plan,loopes.....
    this is may mail adress : sammi_79tn@yahoo.fr
    Mar 2006
    Quote Originally Posted by sammi_79tn View Post
    this is may mail adress :]
    Sammi, Welcome to the forum. However, please read the site rules, and remove your email from your post and add it to your profile.
    You and cleancondenser have alot to discuss.
    Jan 2015
    Dear Sir,
    could you please help me to download any revision of CARE that doesn't need USB dongle.
    I wish your response as soon as possible
