Results 1 to 13 of 34
Thread: Flare fittings
    Flare fittings
    Curious about what you guys think. We see it more in refrigeration than AC, so do you guys use the sweat adapters, that is a flare nut premade that you sweat on, do you flare, or do you double-flare? I use the adaptors under certain circumstancesa) Too lazy to get the flare kit out or (b) tight spaces
    I can't remember the last time I made a flare that was NOT a double flare. Don't trust a single flare..made by me anyway...
    r404a
    Mar 2006
    use the yellow jacket tool.. never used a flaring block since.. only time a flare leaks for me just just tighten it abit.
    ive seen the sweat on adapters (tubing with a flare on it) im sure it would be nice if you needed a flare but didn't have the room to make one
    Nov 2005
    i live by the yellow jacket flareblock which swivels while flaring and CLICKS when the flare is done. for me dummy proof add a little oil then tighten , job done. for really tight spots then maybe ya the sweat type or take my chances on the a normal type flareblock
    what is different about the yellow jacket?
    The best flaring tool had a fluted cone
    But I forget the brand right now. Really excellent flares every time.
    I always run a swaging bit in until it juuuust bells the copper. Then I switch to the flaring cone. The feel of the cone lever changes when the flare is right. It kind of 'gives' a little.
    Flaring a dryer in eliminates cutting it out later.
    PHM
    wedged in freezer shelf
    Think thats the Imperial one that I use PHM
    404 when I see the premade ones that's the first place I leak check
    The Y/J head is offset and rolls around the pipe instead of compressing the whole surface at one time like the others.
    Stupid question, what's a double flare?
    I'll use the premade sweat-on flares if I'm close to a parts house and know I'll need one beforehand, otherwise I use a flaring block.
    the adapters have a really strong point that i like and that is the flare, its extra thick and factory machined , almost impossible to overtighten , great and reliable time saver plus neat work and as stated much more practical for small driers, regards stan
    Keep it simple to keep it cool!
    California
    I make my own flares and also add those copper flare gaskets...anyone else like those things?
    I use copper flare gaskets
    But only on brass-to-brass flares.
    What is the gain in using them inside a regular copper end-flare?
    PHM
    Quote Originally Posted by Phase Loss View Post
    PHM
    Dec 2006
    In a Mess
    Arrow
    Quote Originally Posted by sebastian haff View Post
    Double flares are when you use the double flare tool and it 'bowls"(is that a term?? haha) the copper in ward then you put the 45 degree flare cone over in it which makes the flare twice as thick, so basically the flare seat has 2 layers of copper instead of one. When done properly they make nice joints.
    Mike
    Sig removed by mod. G-Rated site
    California
    PHM
    I like it because it makes the flare twice as thick and I feel like i get a better bond plus i dont know how to make a double flare with my flare yoke and block.
    Dec 2006
    In a Mess
    IU can't say I agree with that, it's like saying using a washer makes a bolt thicker.
    a double flare makes the flare thicker, well the part that matters anyway
    Mike
