Thread: RUN CAPACITORS
    RUN CAPACITORS
    IM shure every ones had problems with run caps on all brands of equipment.
    Ive tried other replacements Global , mars etc. those brands continue to go out , Done ok with Turbo run caps. Can anyone recomend another brand run capacitor ??
    Jun 2009
    NYC
    I have found allot of bad caps,but never had to frequently replace a replacement one.Check the voltage ratting and mfd always use equivlent or higher value.They should'nt fail that fast.
    Virginia
    am rad capacitors they are made in the usa and have a 5 yr warranty
    Sterling Heights, MI
    The largest issue I have seen with caps in anything I have ever worked on including T.V's and things like that is people take short cuts and go with the lowest voltage cap that will work. You see stuff like a 12 volt cap with 11.8 volts going to it which over time will dry the cap up and cause it to fail. When I work on something if there is room put a larger voltage rating in and never see returns because of that. You however don't want to change how many mfd's the cap is only the voltage.
