Results 1 to 13 of 34
    Jul 2009
    Southern Calif.
    Can we talk about Swamp Coolers here?
    I came across this forum while looking for a place to voice my disappointment for the new Champion Evaporator Coolers, but I donít see anything on swamps here. I donít really have a question unless someone has something to add.
    I live in the desert where it is hot and dry which is Prime Swamp Cooler territory. Anyway I just replaced two swamp coolers and the pumps that came with them are crap. If wasnít such a big job of taking them down, I would have returned them. Lucky I still had the old ones and salvaged the old pumps from them. The new pumps leak air and the bubbly water is not able to reach the spill trough.
    Iíve had the old ones for 15 years and Iíve been real happy with them. I change the pads twice a season and only needed to replace the fan belt and bearings every 5 years. I did have to replace the original pump once because I accidently squirted it with the hose while cleaning it and it burnt up.
    I still have my split AC unit for those few days that we get rain and the humidity is high, but I try not to use it because of the high electric rates here.
    Jun 2009
    Albuquerque NM
    Quote Originally Posted by JohnnyB60 View Post
    I hate swamp coolers. I'm in Albuquerque and most of the older homes here have them. It's funny, 10 or so years ago if you asked a builder for refrigerated air they looked at you like you were nuts, but now that's pretty much all they put in unless you are at the bottom end of the price range.
    I hate them because I have allergies and they pull in massive amounts of outside air and humidify it, giving the pollen a nice way to move around your house. The pollen loves it!
    This is why I'm pulling out my swamp cooler and putting in refrigerated air. Efficiency is so much better these days that the operating cost difference is much smaller, and then there's the water used.
    The only swamp cooler I MIGHT consider is the Coolerado, and then I'd have to filter the crap out of the intake air to make it livable.
    Jul 2009
    Southern Calif.
    Quote Originally Posted by garya505 View Post
    Wow, thatís the 1st time Iíve heard that. My wife has allergies and she has never complained. In fact she does complain about the refrigerated air because it dries up her sinuses and she gets nose bleeds. I guess I could add a humidifier, but then that with the AC unit will drive my electric bill really high.
    My house came with refrigerated air and after I put in my swamp, the whole neighborhood installed them. The electric Supplier gives huge discounts if you allow them to shut off the AC whenever they want. They also give rebates if you put a swamp in.
    Jun 2009
    Albuquerque NM
    We can get a rebate here too, but only for the Coolerado or Oasis, and the rebates are small. We also have the power company peak-load shut-off discount, but only if it's connected to your AC compressor.
    Your AC is older, like 10 SEER?
    Colorado flatland native
    I hate Swamp Coolers
    Walter Matthau
    Jun 2009
    Albuquerque NM
    Quote Originally Posted by spotts View Post
    You da man!
    Saint Joseph, MI
    It's amazing... they're in a desert with a limited water supply from the CO river, and Lake Mead getting lower every year, but they still allow evaporative coolers?
    If they priced water based more on future supply rather than current supply, the swamp coolers would disapear overnight.
    Why cool swamps? Around here the ducks fly south every year and the swamps freeze all by themselves. Welcome to the great northeast.
    Fort Worth, TX
    Swampers work only as well as the local outdoor wet bulb allows. I've heard from those who have lived in urban areas like Phoenix that in the early days when refrigerated air was scarce and swamp coolers ruled the day, swampers worked well. As the city became populated and folks wanted green lawns and swimming pools and ponds and lakes in the desert, the city became more humid for longer periods, rendering swamp coolers less effective than in days gone by.
    I lived inland San Diego County years back...I remember warm days with an onshore marine flow the swampers a few folks held onto didn't do well. Let a Santa Ana come in and they did much better. I had refrigerated air, and was fine with it. Even inland there were many days no a/c at all was needed. But when you did, chilled air was tops.
    Building Physics Rule #2:
    Building Physics Rule #3:
    Jul 2009
    Southern Calif.
    water usage isn't even enough to talk about.
    I don't think so.
    Water usage is very small compared to oil or coal to produce electricity.
    The water in a swamp cooler is collected in the bottom and recycled through the pads. The only water usage is the evaporated water.
    According to the consumerenergycenter.org, a swamp cooler can use between 3 to 15 gallons of water a day under normal conditions. Itís been a while since I actually measured it, but that about right. I use more water to water my lawn and I read somewhere that the evaporated water from a swimming pool was far more than a swamp cooler.
    Jul 2009
    Southern Calif.
    Quote Originally Posted by shophound View Post
    Swampers work only as well as the local outdoor wet bulb allows. .
    This is absolutely true and this is why you still need refrigerated air as a backup.
    Arizona
    I don't think so.
    According to the consumerenergycenter.org, a swamp cooler can use between 3 to 15 gallons of water a day under normal conditions. It’s been a while since I actually measured it, but that about right. I use more water to water my lawn and I read somewhere that the evaporated water from a swimming pool was far more than a swamp cooler.
    How about 3 to 15 gallons per hour! You should be bleeding off 12oz. of water every 90 seconds to keep your scale down. Do the math.
    Don't believe me, turn off your water for an hour and look in the wet section.
    Jun 2009
    Florida
    Vegas lives on water cooled centrifugals...there's like 3000 of them in the metro area, and they all use evaporative cooling as the first stage of cooling, so to speak.
    Low Pressure Forever!
    If you know heavy metal, you can work anywhere-Dave Andreson
    Anchors Aweigh my boys, Anchors Aweigh!
    Farewell to foreign shores, We sail at break of day. Through our last night on shore, Drink to the foam. Until we meet once more. Here's wishing you a happy voyage home!
