Results 1 to 13 of 22
Thread: Blower Motor not running
07-20-2009, 11:36 AM #1
- Jul 2009
- 7
My blower motor (in the furnace compartment) stopped running the other day, the out side unit runs fine. A service tech found that the high speed wire was loose and reconnected. He also found the motor was running a little hot after a few minutes of operation, said that may have caused the connection to loosen from excessive heat. The next afternoon the motor stopped again, I check connection and it still doesnt run. I pulled the assembly and the motor spins freely and doesnt have any "electrical smell" , it is about 8 years old.
Question, could the run capacitor be the issue and is it likely the motor went bad and still spins freely? Also being in Las Vegas the motor deals with heat from running and an attic that is about 170 degrees , any specific brand of motors that deal with extremes better?
07-20-2009, 11:46 AM #2
If the motor was running hot when the tech was there, why didn't he suggest you replace it?
07-20-2009, 11:55 AM #3
- Jul 2009
- 7
Blower Motor
Was running a little hot at the time. Question is it likely that caused failure and it still spins freely and has no smell if the motor went bad? Thanks for your help
07-20-2009, 12:03 PM #4
Professional Member*
- Oct 2003
- las vegas
- 1,505
that blower motor is living in the best of conditions & should have not been running hot. tech may not of had motor on truck but should have noted
that it needed changed.
07-20-2009, 12:07 PM #5
- Jul 2009
- 7
Thanks for the help
Sounds like I better get a new motor and run capacitor and put it in. In fact i recall it hit 127 in a fairly short period. Any particular brand of motor to get or do they al perform about the same.
07-20-2009, 12:10 PM #6
- Oct 2003
- las vegas
- 1,505
call the trch back. may not be the motor causing the problem.
07-20-2009, 12:12 PM #7
So.
What part of no DIY is not being understood here?
Do not argue with an idiot. He will drag you down to his level and beat you with experience.
07-20-2009, 12:13 PM #8
Well, there's definitely something not right. Call the tech back and have him re-check, but I would imagine a blower motor in your future.
This is about all I can say in the open forum without getting a slight correction from the mods........
07-20-2009, 12:22 PM #9
- Jul 2009
- 7
He had check the circuit board, check the voltage and amps, all checked out ok. The only two issues identified where the loose wire and operating temp, which was 127 after about 1 1/2 to 2 mins of operating
07-20-2009, 12:38 PM #10
- Jul 2009
- 7
Passed experience with electric motors had always involved freezing and an "burnt smell"
07-20-2009, 12:43 PM #11
We are not allowed to give DIY information on this website.....
Call your service company back and have them re-check this issue.....
Off the top of my head I can think of 5 or 6 things that could be your issue and none of them are the motor.....
Don't start wasting your money on part changing.....let a qualified technician come out and save yourself some money and headaches.....
BenderI need a new signature.....
07-20-2009, 03:08 PM #12
I'll bet it's the thermostat. It's always the thermostat you know!
07-20-2009, 03:10 PM #13
It could be the ID-10-T switch.............
