Results 1 to 9 of 9
    Jul 2009
    HVAC Copper fittings...
    What is the best source of supply for copper fittings? What company or companies would you recommend? If you buy them online what websites?
    Appreciate your help!
    Most of us buy them at our local supply houses.
    Oct 2007
    Broward County, FL.
    One of the main companies is Mueller, yellow and blue label on their boxes.
    Austin, TX
    Any copper over 1" United Refigeration. They carry copper up to 3".
    Southeastern Pa
    Quote Originally Posted by hvac-guru View Post
    I would hesitate to buy consumables on the web (other than on websites of known good suppliers) because of the risk of inadvertently purchasing low quality or counterfeit parts.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Jun 2009
    I buy at my local Johnstone. I prefer to pump the money in my local economy. It goes both ways. Buying local helps the merchant, and in turn, it helps me because anytime I have a question or need advice or a hard to find part, they help me the best they can.
    Apr 2008
    TEXAS
    don't use them much anymore except above 1". hydraulic swage and bender ended that. well, that and the price.
    "When the people find they can vote themselves money,that will herald the end of the republic" - Benjamin Franklin
    "Government is not reason, it is not eloquence, it is force;like fire, a troublesome servant and a fearful master. Never for a moment should it be left to irresponsible action"- George Washington
    Me too but mines not Hydraulic
    New Mexico
    You will probably only be able to find refrigeration fittings (long sweep) at a refer supplier. The water fittings are comparatively cheap and available all over. I use my wholesaler though.
    I should have played the g'tar on the MTV. MK
    You can be anything you want......As long as you don't suck at it.
    SMW Lu49
