Results 1 to 10 of 10
07-17-2009, 09:29 PM #1
- Mar 2006
- 949
Its a friday night, and this is how i spend it
1st time using stay brite 8. Never tried soft soldering before, always brazed. Im liking what I see so far, for 3/8 and 1/4 line heats up in a few seconds with just a propane torch, no more 30lb oxy/acc rigs to haul up a roof
For work inside small areas (reach ins) this would make my life so much easier. Lets me know what you think
Im gonna let it sit overnight and see how it holds up, been about 30mins so far
07-17-2009, 09:38 PM #2
You haven't finished the wiring yet, right?
- Alexis de Toqueville, 1835
07-17-2009, 09:45 PM #3
- Mar 2006
- 949
missing... wiring, thermostat, condenser, compressor.... someone stole it i guess
yeah just im fat so when i have to install in evap. in a reach in i put it together and leak check the coil/txv/solenoid the night before i install it
i dont fit good inside small areas
thats just 120v for the solenoid from my garage outlet, i only put in a fitting on the suction side, so i need to open the valve to get the nitrogen to flow to the high side
07-18-2009, 11:08 AM #4
- Mar 2006
- 949
pressure held all night, even pumped it up to 300psi.. im impressed
just takes a few times to get used to applying the flux first, i forget and had to redo one joint
07-18-2009, 11:10 AM #5
wondering about vibration test also...put it under 300 psi and have a auto thumper/shaker of some sort.
07-18-2009, 11:37 AM #6
- Mar 2006
- 949
07-21-2009, 06:26 PM #7
- Mar 2006
- 949
UPDATE:
Installed it monday, haven't had an issue yet
07-21-2009, 06:34 PM #8I need a new signature.....
07-21-2009, 07:29 PM #9
- Mar 2006
- 949
07-25-2009, 06:09 PM #10
For small valves and such, this stuff is awesome. As long as you can get a good clean fit up, apply the flux properly and don't overheat the pipe or solder, this stuff will hold almost anything that your basic refrigeration system can throw at it.
It's just not as forgiving as old oxy/acetylene w/ 15% when you mess up.
