Results 14 to 26 of 28
    Austin, TX
    Trane condenser coils are made of aluminum and can be repaired.
    It is also possible to replace just the coil if it is still available.
    Either would be cheaper than replacing the whole heat pump system.
    I am for doing good to the poor, but...I think the best way of doing good to the poor, is not making them easy in poverty, but leading or driving them out of it. I observed...that the more public provisions were made for the poor, the less they provided for themselves, and of course became poorer. And, on the contrary, the less was done for them, the more they did for themselves, and became richer.
    ― Benjamin Franklin
    golden horseshoe
    check all connections first
    Jun 2008
    NW Florida
    Quote Originally Posted by allan38 View Post
    How? I have tried aluminum welding and epoxy. They will last about a year and you can see both the epoxy and the weld coming loose from the original tubing. Any info would be apreciated.
    Jun 2008
    NW Florida
    I do recommend you get a second opinion. Because as some one stated before. A leak in the condensor coil would loose all of its freon within days. And it could possible be in a connection or distributer tube that can be repaired. I have found that most leaks in tranes is at the evap coils.
    Quote Originally Posted by meoberry View Post
    Let me start by saying that I have exactly ZERO experience repairing Trane coils.
    It is possible to repair an aluminum coil, however.
    http://uniweld.com/Larger_View/uni4300_1lg.jpg
    That is the stuff that I use. It is a trick to get done, but I have repairs that have lasted for years in a low temp application with hot gas defrost.
    I get it at United.
    Arizona
    Here ya go.
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
    Really?
    It's that easy?
    Do they come in different sizes? Do they LAST?
    Arizona
    Really?
    It's that easy?
    Yup pretty easy. I believe they come in only 3/8, but I could be mistaken.
    I've used them once or twice with no further issues.
    Hmmm.
    Another nugget in the trouble-solving arsenal.
    Thanks.
    omaha
    Talking
    at least two sizes available, so far so good
    KIT 01146 is for 3/8" tubing, which is what is used in all the residential equipment.
    That same kit has been available for at least 15 years. It has probably been available since the 60's when GE first started making units with spine fin coils, but I can only speak for its availability for the last 15 years I've been doing service work.
    There is another kit for the 1/2" spine fin tubing used in old GE/Trane commercial equipment.
    If you follow the instructions and install the thing correctly, it is a permanent leak free repair, even for R-410A equipment.
    Sometimes, due to access limitations due to the location of the leak, you may have to think outside the box a bit.
    The last one I did I used 2 of the kits and about 10" of 3/8 copper pipe to repair one leak.
    The leak was right in the center of where all the copper lines passes under the coil on a XL1400 heat pump that has a double coil, so there were several copper pipes crossing under there, and not enough room to work. I cut the spine fin tubing on either side of where all the pipes passed under, and spliced in a piece of copper pipe with a coupler on each end.
    I keep 2 of the 3/8" kits on my truck. I may go 2 or 3 years in between needing one, but then end up needing 2 in one day.
    Fortunately the cabinet design changes in 2002 pretty much eliminated the most common cause of leaks in AS/Trane outdoor units.
    Jul 2009
    Again guys, thanks so much for the information. I'm printing all of this out and forwarding this to the guy who did the inspection. I called my realtor and she called the inspector who called me yesterday. There's a good chance part of this can be covered by the insurance on my home inspection.
    I wasn't with him all the time. He showed me the "wand" and said that meant it was leaking.
    Jack
    PS: I talked to the home inspector yesterday. He turned on the AC but said he didn't turn on the heating part of the units as it was above 65 degrees. I had misunderstood what he meant.
    Quote Originally Posted by dehavenphoto View Post
    Jack
    He will need to use a soap solution to pinpoint the leak before any repairs can be made. The 'wand' or electronic leak detectors are great for finding the general location of a leak, but rarely can the pinpoint a leak with any degree of accuracy. Only a good soap solution can do that.
