+ Reply to Thread
Results 1 to 9 of 9
Thread: fieldpiece hs-36?
    louisville, ky
    fieldpiece hs-36?
    do u have to pull the head off every time u wanna check amps on this meter, i have the lt17a which i like very much, but want an amp clamp style that has true RMS. but if i have to pull the head off to go back and fourth from amps to volts then ill stick with my lt17a cuzz thats what i already have to do all day long. i like the sc77 but is not true RMS, just wanna be able to clamp on and read amps and switch it to volts without changing heads 10 times a day. im open to any other brands that might do all this and be true RMS.
    Oct 2007
    Anaheim, CA
    Quote Originally Posted by Vettgetsmwet04 View Post
    FYI the SC77 IS True RMS.
    louisville, ky
    well then that might be the one for me. ill have to look at it again
    Oct 2007
    ATLANTA
    The SC 46 will give you true RMS and it is smaller and lighter than the SC77 if weight and size are issues for you.
    I have used the heck out of my SC 46 for nearly 3 years on PM and service work. It easily fits in small tool belts and has most features needed for general HVAC service work.
    Best Regards
    Lee Adams
    Dec 2006
    TN
    did your lt17a come with the amp clamp? if not you can purchase it seperatly
    Jul 2005
    What type batteries does the sc 46 use?
    The Bill of Rights ARTICLE II "The Right of the People to Keep and Bear Arms Shall NOT be Infringed".
    [SIZE="4"]
    Oct 2008
    Fullerton
    Quote Originally Posted by nratom45-70 View Post
    2 x AAA batteries.
    Jul 2005
    Quote Originally Posted by RussellHarju View Post
    2 x AAA batteries.
    That's a good thing! I've eliminated my meters that took special batteries, it's just a pain locating them.
    [SIZE="4"]
    louisville, ky
    yes my lt17a came with an amp clamp, u just have too pull off the ends and put the amp clamp on the leads coming off the meter, i bought the sc77 and love it much better than my lt17a, much more compact, and can clamp onto anything at anytime with switching the heads
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
