Results 1 to 13 of 15
    May 2005
    Confused part info needed..
    i pulled a fan delay switch off of a a unknown named evaporator in a reach in freezer..cant find this switch in the johnstone or uri catalog, heres what i have.
    numbers on switch in this order from top to bottom:
    37T23
    43564
    L50-20
    8429
    no manufacture name, has the two red and one black wire..
    i cant find it anywhere..
    May 2005
    also as an aside, could someone make a cartoon showing me how this 3 wire switch works?? thanks
    May 2005
    thanks for the link dandy,it helped some..ill commit it to memory..but i would like to get a direct replacement for this one..if i can.
    florida
    Quote Originally Posted by primmers View Post
    37T23
    43564
    L50-20
    8429
    That should not be to hard to find the it's a open at 50 closes at 20 defrost term fan combo. Supco has one that's 55 open 35 closes pt# SL5709
    Educational forums are open.
    May 2005
    thanks cracker, i ordered one..
    Dec 2006
    In a Mess
    use a johnson A419, total accurate control!!
    Sig removed by mod. G-Rated site
    May 2005
    Ok mike, ill check that out too..
    frickin trailer park boys cracks me up..i dont miss a show..
    Dec 2006
    In a Mess
    clamp the A419 temp sensor on with the TX bulb and it gives a good visual on suction temp for future use, that only works good with gas defrost though, if you have electric you'll have to mount it where the old klixon was.
    mike
    Las Vegas NV
    37T23
    43564
    L50-20
    8429
    This could be in a True box. Check out Johnstone part# B14-712. The 37T23 crosses to this.
    May 2005
    the switch i ordered got lost in the mail..and i need to get the system going..how would i wire past this 3 wire switch..2 red 1 black wire..
    May 2005
    somebody???
    theres no cartoon on the 40 year old system and its remote .
    i guess i could take it apart and finger it out....
    Jul 2000
    Guayaquil, EC
    If you need to bypass it (temporarily)...
    One wire is the common or hot, one is to power the fans and the last one goes to the "X" terminal on the clock for termination.
    Just disconnect the termination and tie the fan wire to the hot wire.
