Results 1 to 13 of 13
    Jun 2009
    Insulated line from condenser
    Is it normal for the insulated line from the condenser to have sweat/condensation on it? It is happening on both the end outside as well as the end by the indoor coil (dripping a little as well).
    Yes, it normal.
    Jun 2009
    Yes, it normal.
    Thanks. There is about 3 inches of suction line that is not insulated outside before it goes into the compressor compartment. Should that line be insulated all the way to the compressor or is the length of it not always insulated?
    Quote Originally Posted by david8370 View Post
    Not important outside if it is just a short section of the line.
    It would be important enough, to not pass inspection around here.
    Jun 2009
    Quote Originally Posted by the dangling wrangler View Post
    do you normally insulate the suction line all the way to the compressor?
    To the access fittings/service valves. With the energy code, the inspectors "have" to be a bit on the picky side.
    Jun 2009
    Would it be detrimental to insulate all the way to the compressor itself inside the casing?
    Chicago, IL
    It's not detrimental, but it would not provide enough benefit to be worth it.
    on the other hand if you have exposed line at the indoor coil, you should insulate it to prevent it from dripping on the furnace and rusting it or damaging an electrical component
    Have to agree with craig.
    Jun 2009
    Thanks again for your input, guys.
    You forgot to ask where to send the check.
    golden horseshoe
    Insulate all ofthe suction line
