Results 1 to 13 of 14
    Jun 2009
    Attaching R6 flexible ducts
    Just had a complete new system put in. New furnace was moved to the attic. Is it acceptable to secure the R6 flexible duct to the cans, tee ys, dampers etc. with heavy duty zip ties and nothing else?
    Dry as a bone Tucson
    Quote Originally Posted by dbahz View Post
    No!
    Watchman Nee
    Jul 2009
    gods country maui
    No is right. Now your gonna have supply leaks that cause your house to go into a negative pressure sucking air from every crack and crevice tell them to come out and seal your ducts
    If they say they are sealed enough then tell them to prove it by doing a duct blaster test
    Leaks in forced air duct systems are now recognized as a major source of energy waste in both new and existing houses. Studies indicate that duct leakage can account for as much as 25% of total house energy loss, and in many cases has a greater impact on energy use than air infiltration through the building shell. Just as important, duct leakage can prevent heating and cooling systems from doing their job properly, resulting in hot or cold rooms, and humidity problems. Worse yet, duct leaks can create air quality problems by pulling pollutants and irritants directly into the house.
    MI
    Yes, this is fine. Only it should be two zip ties for every connection: one for the inner sleeve and another for the outer one. This is a code.
    Jun 2009
    NAPLES,FL
    Cool
    NOOOOOOOOOO, also silver tape and mastic.
    call them back, and have them do it right.
    Jun 2007
    Round Rock
    Quote Originally Posted by francosair View Post
    The right way is zip ties and mastic. Using tape it runs the risk of temperature changes causing the glue on the tape to unstick. (You ever try using UL foil tape when the attic is hotter than crap, it doesn't stick well) If you really want a good seal. Coat the starting collar with a light coat of mastic, slide the inner liner over it. Zip tie it. Put insulated part over it, zip it and apply mastic.
    I like DIY'ers. They pay better to fix.
    lets not give step by step instructions.
    Jun 2007
    Round Rock
    Sorry. I figured they can't do too much damage to themselves other than the finger cut from the starter collar and mastic in the hair and clothes. Worst case, their wife will beat their arse from trying to get the dried mastic out of the pants and shirt.
    Aug 2008
    How can wus homeowners know if a job is done correctly...
    if we don't know how it is supposed to be done correctly? Other then to pay someone else big bucks to fix what we already paid big bucks to have done the first time?
    How about a thread (maybe even locked to pros, but visible to all) that shows the top cheats (shortcuts) and pictures of what we should expect our installs to look like so us homeowners can know we are getting what we paid for?
    Aug 2008
    Is code good enough?
    Quote Originally Posted by gena View Post
    I believe this was also built to code ... http://www.lib.washington.edu/specia...tnb/fall7b.jpg
    OK, just kidding... But seriously, when we homeowners pay large amounts of money, shouldn't we expect that our systems will be installed in a way that will last for the life of the house? And be done with materials that will not fall apart a day after the warranty is up?
    For example: Code only requires a single smoke detector per level (some areas at least require them in bedroom). But they can use the cheapest (not anywhere near legal to use in commercial) smoke detector. Should we only expect a home builder to use the cheapest materials he can just because it passes code?
    Jun 2009
    Thanks for all the replies.
    The contractor said he was going to install the system just like he would at his own home.
    I will insist that he return and do it properly.
    I was mostly talking to the poster, of the post I deleted.
    You can check out the wall of pride, and the wall of shame, if you want to see some of the differences.
    MI
    Bmathews: “Coat the starting collar with a light coat of mastic, slide the inner liner over it. Zip tie it. Put insulated part over it, zip it and apply mastic
    Man, it is just ridicules, it is why you got that mastic:
    “and mastic in the hair and clothes. Worst case, their wife will beat their arse from trying to get the dried mastic out of the pants and shirt.”
    Can you just stop for a while and check it out how tight zip tie actually attaching the liner to the collar?
