07-07-2009, 11:58 PM #1
- Jun 2006
- Omaha,Ne
- 43
Cleaning Evaporators in Prep Tables
I was working on a randell prep table today iced up solid.Bad fan motor but as I was defrosting it there was black slime all over coil normally I just hose off but whatever this is doesnt want to rinse off.Is it ok to use coil-brite on these coils its 2yrs old or just use bleach and water thanks in advance.
07-08-2009, 01:53 AM #2
- Jun 2009
- texas
- 54
coilcleaner
as long as there not coated coils and you can rinse them off good should be fine
07-11-2009, 11:08 AM #3
- Mar 2008
- Florida
- 191
Not sure about coil brite as that is pretty corrosive. I have been using simple green with very good results.
07-11-2009, 12:09 PM #4
- Jun 2006
- Omaha,Ne
- 43
Thank you for the replies ended up using hot water and coil brite worked but probably will start looking for something else to try.Simple green sounds like it will be used next time just never had an evaporator so packed with what looked like mold.
