    May 2009
    Split systems vs. ductless
    Why are the condenser units for ductless systems much smaller than conventional split system condensers of similar capacity and efficiency? For example, a high SEER 3 ton conventional unit can weigh about 350lbs and occupy a 3' x 3' x 4' cube. A 3 ton condenser for a ductless system, however, measures only 3' x 3' x 1', weighs less than 100 lbs, is several dB quieter, has less than half the LRA of a conventional unit, and has the same efficiency overall.
    Are manufacturers of conventional split systems just behind the technology curve or is something else going on here?
    Apr 2004
    Charlotte, NC
    All in the engineering, all in the engineering....
    May 2009
    Earth
    Even the 5 ton units don't weight 350 lbs, put a few of them on roofs.
