    Chicago
    capacitor sizing-replacement???
    Last week I was on a job that had blown 35/5 mfd capacitor on acondenser unit. In a pinch we replaced it with a 40/5 - will this cause premature failure or any other electrical problems..The voltage rating was compatible....
    I think you already know the answer to this question.
    You have the posts, why not apply for pro?
    Sep 2003
    Portland.OR
    FOR AWHILE ....GET THE RIGHT ONE
    Caps are usually 20% tolerance value, so a 35 -or + would be up or down 7 uf.
    Therefore 42 would still be OK. [35+7=42] Some have 10% tolerance depending on the circuit. 40 will work if its a 20% value on the old unit, dig it outa the bad parts box. Read the label...make the decision.
    Next time in the area put in the proper size, if its a 10% cap.
    caps can short/open/change value/or the ESR changes
    Over and out!!
    Northeast Ohio
    Carry a multi-cap and save the hassle
    DEM
    Quote Originally Posted by jmiles View Post
    will be ok, just increased starting torque a bit and lost some efficiency of the motor
    Quote Originally Posted by heaterman View Post
    if this was in pro area..... cost prohibitive, can i say that?
